Some progress on my Rickman build. So I've got the bottom end finished and installed the engine in the frame. Waiting to put on the top end just because it makes installing it a bit easier with having to move the engine a bit for alignment. It took a lot of adjusting and filing and some drilling to get the engine mounts, engine plates, etc. to align properly with the frame. Also needed to pay attention to the rear hub/wheel for alignment. I'm using a BSA quick detach hub for the rear and am having to alter the center boss of the brake plate to get clearance for chain alignment. I finally received the axle from Adrian Moss at Rickman. The Royal Mail was hacked a couple of months ago so it took 2 months for the delivery to happen. There is a lot more fitting on this build than I first thought!
