Rickman Triumph Project
Here are a few more photos. The brass cylinder is what came out of the hole. It was not threaded into the case, just fixed in there with some silicone or black goo. Plus, the cylinder itself was plugged with goo. It doesn't look like a standard item.
On MY bike, I would re-use those pistons & cylinders with a light smear of engine oil only, on re-assembly (not in the rings)
The fitting is for earlier models' speedometer drive, and would need the proper gear, and the associated speedometer.
I have never liked combining primary chain oil with crankcase oil. I'd plug everything up, install a seal, and revert to the timed breather setup with a catch bottle instead of an exhaust pipe out back.
Thanks all. I prefer going back to the timed breather setup. So will probably just plug the hole with silicone and use the same case. Learning something new all the time!
Left and right crankshaft bearings - Question. I did not realize there were about 3 different bearings for the left and right side of the crankshaft, marked CN, C2 and C3. I didn't realize this when building my last engine, and will have to look through my receipts to see what I installed. Can anyone explain this issue and how one determines which bearing to use in a 1967 T120R engine. My parts book says the part number are E2879 for the main bearing left, and E1591 for the main bearing right. Thanks for any advice!
Those tolerances have never seemed to cause any problems in nearly 30 years and over 100 overhauls, restorations & custom builds. I always ordered by part number from one of the same 3 main supplies (JRC mainly) and have NEVER had a bearing or bearing-related failure. I think when you build a performance engine, spending bigger bucks and expecting higher performance (racing, typically), you start to delve into the finer details. Not me.
Thanks grandpaul. On another forum an inmate provided a chart from CBS on which bearings are supposed to go in what engines referring to CN, C2 and C3. I didn't notice the CN designation when I did my first and only engine last year - so it sort of threw me when I was looking for bearings for my current engine. I am not trying to build a race engine, just some thing that will be relatively reliable.
Transmission main shaft a bit worn. So I disassembled my transmission and it all looks pretty good except for the transmission main shaft. I don't know if this kind of wear makes this unserviceable and would appreciate any comments in this regard. Thanks!
Transmission main shaft a bit worn. So I disassembled my transmission and it all looks pretty good except for the transmission main shaft. I don't know if this kind of wear makes this unserviceable and would appreciate any comments in this regard. Thanks!View attachment 53275View attachment 53276
If you re-instal the respective gears to that worn shaft, is there a lot of play, you know, real loose and clattering-about and such like? If not, I might suggest using synthetic gear oil upon reassmbly. I find that synthetic oils have reeeel good lubricating qualities and stanch further wear as much as can be expected. The only alternative is, uh, new, SUPER-EXPENSIVE parts! Aaauhg!
No, there is not much play, but it is obviously worn.
"speedo-drive on the rear axle." I wonder (to myself), which one was/is the better?
The C range (350 and 500 twins with unit engines) have a different gearbox, cannot accommodate a speedo drive, always had a rear wheel driven speedo (gearbox supplied by Smiths), used the same rear hub as the 650. So it did not make a lot of sense to have extra manufacturing processes and make extra parts (gearbox speedo drive, spacer for the rear wheel in place of the Smiths gearbox) for the 650 when the 350/500 parts would fit.
I have found a used main shaft that looks to be in very good shape and is not too expensive, so I think I'll be using that on this re-build.
First, get access to a good set of v-blocks block and dial guage. If it checks out, get it dye or magnaflux tested. The cheaper it is, the MORE it will cost if it's got a nearly invisible crack!
Grandpaul, ok some more learning for me. I've never used v-block before but I can see why I'd want to. Thanks.
Cylinder base dowels. On my motor, two of my cylinder stud holes have a cylinder base hollow dowel recess for the dowel that is in the cylinder. I am unsure of the purpose of this setup and would appreciate any comments to explain this. Thanks!
