Have you read this ?
https://en.m.wikipedia.org/wiki/Devil_Dog
No, looks interesting. Thank you.Have you read this ?
Very well stated, Rocky.I don't think it hurts to share a bit of our personal lives - and I know you weren't looking for sympathy.
But this is a friendly forum, so it was natural for many to just be kind.
For example, CarlS and I have been members here for 15-16 years and we know a bit about our own private lives.
It's the kind of long-distance friendship that develops over the years.
You are clearly a man of words, and I enjoyed reading your message above![]()
I have to admit that I did always rather like the original side panels, although many were junked and replaced with older style ones. The original passenger grab rail set the bike off nicely too.So, took some fiddling but made some templates for the side covers, transferred them to a sacrificial (and too thick) piece of aluminum, made the bends, and adjusted things a bit. Made finished templates, cut them out with the saber saw (duct tape on the foot to avoid deep scratches), and looks like they'll fit well.
I then made up a little die with some hard maple I had laying around and a forstner bit, and pressed an indentation with a socket into the extra piece of aluminum I bought for experimentation... and voila. There will be a nice recess for the ignition switch's bezel to nestle into.
I had wanted to make an oblong recess in each cover, into which to put the waterslide decals (over white paint along the bottom of the recess), but the Bonneville script is too long to fit onto the flat, rearward area of the cover before the gentle radius that follows the frame tube and seat profile. So, I may just put a stripe along the covers--white with a pinstripe to match the tank and fender color--and lay the water slide over that, straddling the large, gentle radius. Then, polish up the balance of the covers to a mirror finish and throw some clear coat on top. Should look cool with the K&N filters...
I started to read your journey regarding the Bonneville restoration. Very interesting indeed seeing I'm involved with a 1976 T120 Bonneville project. Keep up the good work and be safe out there.Okay, all done! (...and please ignore the dust all over her...)
I was mirroring the lean angle of my $1,500 commuter-mobile, and it's reasonably close. When you're kicking the bike--while standing on the R/H side--it actually 'rolls' around its long axis, taking weight off of the kickstand with each stroke.
But, regardless, that new combo butt & lug is beefy and I think I got good penetration, so... yeah, ready to get her going at long last!
The photos in your #609 post concern me - extended, the "foot" appears to be ahead of the pivot? If yes, you know if you ever forget to retract it, it will tip the bike over at the first left hand bend?kickstand
There are posts in various forums. Never tried it myself as all say the hardest part is crimping the new bezel neatly. Probably not an issue if you have a lathe and can make a suitable tool but, as I do not have a lathe ...speedo
online pamphlets for these gauges?
Happened to friends - in their case, the rider had retracted the stand but its spring broke as the bike approached a left hand bend; as we ride/drive on the left, both rider and pillion hospitalised with serious injuries as the stand tipped the bike over in front of an oncoming car.
Currently restoring a Honda 125 for my daughter (learners are restricted to 125 cc until they pass the first two tests towards a motorcycle licence). Although when deployed, its kickstand foot does not go further forward than the pivot, I have replaced the original kickstand with one from a 1980-on Superdream - these mount a wedge shaped rubber beside the foot: no weight on the kickstand, the thin end of the wedge extends below the kickstand foot, bike moving, that hits the road surface first, flips the stand up before anything solid hits the surface; weight on the kickstand, the thin end of the wedge bends until the foot reaches the road surface.
There are posts in various forums. Never tried it myself as all say the hardest part is crimping the new bezel neatly. Probably not an issue if you have a lathe and can make a suitable tool but, as I do not have a lathe ...Restoring/servicing speedos and tachos is one of the few jobs I pay an expert.
