TRIUMPH MAIN BEARING:
RHP MJ 1 1/8" C3 BALL part number 70-1591
This crankshaft bearing was fitted to all Triumph 500 and 650 Pre-Unit twins on the drive side from 1938 to 1962 and timing side from 1955 to 1971.
Triumph engineers want you to put a C3 clearance bearing on the timing side so when the crankshaft expands from heat it won't cause a "nook-yoo-ler" meltdown of the bearing and race and side cover.
RHP are fairly standard original equipment bearings, BUT, they cost more than, say, Fafnir or SKF or other big-name manufacturer worldwide, I have found.
