Fitted the 7 plate clutch yesterday and all seems well. The material on the new bonded plates is completely different to the originals with what appears to be brass fragments in the mix. By comparison, the originals had absorbed oil, which was causing them to stick onto the steel plates.
Interestingly, the TSS has a "7 plate" clutch as standard.
This is achieved by making the clutch housing a bonded plate by glueing the clutch material directly to the housing as can be seen in the photo. Then alternately, a steel plate, then bonded plate...etc are fitted ending with a steel plate against the pressure plate. The standard TSS clutch has 7 steel plates and 6 bonded plates plus the bonded housing. In the parts manual it only lists 6 bonded plates and 6 steel plates, which would make the first plate to be inserted a bonded plate as described in the workshop manual. With the TSS's bonded housing, the first plate to be inserted is a steel plate. It appears that the extra power of the 8 valve engine, required this factory upgrade.
The 7 plate upgrade kit provides 7 bonded plates plus an extra steel plate to be used with the existing 6 steel plates. On the non TSS clutch, the bonded plate is fitted first, which seats onto the face of the clutch housing, then the remaining plates fitted finishing with a steel plate against the pressure plate.
In the case of the TSS, with its bonded housing, it was tempting to fit a steel plate first, however logic prevailed and I decided that the old bond material on the housing would stick to the steel plate and I would still have a sticking clutch. Having measured the standard clutch pack thickness of the old clutch at 34.4mm and the new clutch pack at 33.6mm, I knew that I could fit a new bonded plate first, which rests against the bonded housing and all would be well.
After a run yesterday and sitting overnight, I checked the clutch this morning and it released immediately. I will run it for a few hundred miles before confirming the upgrade a complete success, just to see if the new bonded plates absorb the oil and start sticking. Will report back with my findings.
