I wish you a full a complete recovery from your knee surgery. Yes, electric start is a very nice feature.
![Mae4a.jpg](https://proxy.imagearchive.com/0b9/0b94800e334d4546d0682f873312a630.jpg)
Hi All
Been laid up for a bit due to Knee Op (Good job the TSS has electric boot) hence not had much to say about progress.
She is all ready for the road now, just finished syncing the carbs (last used up a fair bit of time) it apears to have been the source of the issue I had with the slight missfire feeling.. Once warmed up she ticks over like a swiss watch (well i think so).
The original tyres passed the roadworthy bur will be replaced before she goes on the road. No luck in getting the AVON's so TT100's it will have to be.Still got a couple of minor jobs to finish off, but one of them has me stumped, so hoppfuly someone can help.
The tank is touching the throtle cables on the 45 degree bend piece going into the carbs (Bings), as first i though it was the tank rubbers worn? nope new ones made no difference. I've had to re-fit/adjust a few bits around the bike as it seems to have missed the quality control process at Meriden.
I tried adjust the inner air box as it looked like the carbs are tilted up, but no real adjustment is there, it occured to me that they (triumph) may have cut the holes in them too high, but looking at the rebuild pics of SD bike (great point of reference SD thanks) they look the same.
Bugging me this one, so any suggestions welcome..
Cheers
Mike
Hi Carl/SD the knee is on the mend nicely, thanks for asking.
I've since taken to adding some height to the tank rubber which has given some clearance for the cables (around 3mm also), I think we will have to put this build quality issue down to the time of bike being built as the Bings were only for the US market (emissions) so not as much thought might have been put in to things.
I'll keep that in mind about the timing, what fuel do you use?
TT100's arrived today, so need to get the wheels off and up to the tyre (Tire for our US readers) shop. I know I said I was not intending to restore the bike and keep it (apart from a bit of clean an polish) as was. However, the wheels are a bit scruffy and since buffing up the alloy edges they look worse. So a lick of black paint has to be given. That will be it though, there is enough immaculacy presented, prize winning show ponies on this site(You know who you are).
I was at a bike show on Sunday and came across the is interesting Triumph ratty café racer, thought it might inspire someone to use all the old broken bike bits they have lying around the shed.
View attachment 2387View attachment 2389View attachment 2388
Cheers
Mike
See that's what you get when you use your bike.... do what i've beeen doing and just imagine what it would be like to ride
British Spares NZ list the sprag bearing, not cheap at $128.29 AU but they show plenty in stock.
60-7291 SPRAG BEARING,START CLU,T140ES 128.29 172.11![]()
The plan is to get the bike registered next week, as I have to take the bike to QT (Queensland Transport) finding the time is the only problem i have (very busy at work just now)..
Where did you put the QT Mod plate? I'm loathed to rivet it on the frame downtube as recomended by the engineer...
This is where my one ended up Mike.
