Finally got to spend the afternoon in the garage working on the TSS. Definately mechanical therapy!
First of all I should explain that I had drawn up a more conventional head gasket and had Lani Visconti make me a couple.
I like this solution better than the rings because the head is supported around the bolt/stud locations. I felt the cantelevered loads could not be good for keeping the head flat! We'll have to wait a while to know if the sealing is as good as the rings but I see no reason why it shouldn't be.
The pistons went on the the rods without any reall issues. I froze the pins and heated the pistons and small end with a heat gun. It all slipped together quite easily assisted by a thin coating of Graphogen - i think this stuff is one of the UK's secrets to engine building! I bought the DuPont equivalent and it feels like grinding paste by comparison!
Next I prepped the surfaces and cylinder gasket. I had been advised by a friend of mine who used to work a Cosworth that they used Permatex Ultra Black on everything including F1 engines - seems like it should be good enough for me, so a light smear on both faces of the gasket and it was dropped in to place.
With pistons and gasket in place and some nice hardwood spacers under the skirts to hold the pistons vertical I gave everything a liberal coating of Amsoil engine assembly oil and fit the ring compressors. I made sure that the ring gaps were evenly spaced at 120 degrees from each other, but honestly I feel that this is a bit of a myth. I think the rings move around the piston all the time the engine is running.
The cylinder slid on quite easily once everything was all lined up correctly. I made sure the rings were all the way in the bore and then popped of the ring compressors. A bit of a pain getting them off, but they did come away with a bit of effort. A little more Ultra Black where the wood spacers had removed some and the cylinder was pushed all the way home. Very satisfying!
Oh and by the way I had not forgotten the tappets, even though I did forget to write about them in the correct sequence! They were checked over and a couple of sharp edges were stoned down before a nice coating of Graphogen was applied all over. I used small 'O' Rings to keep them from dropping down during the assembly. The base nuts were tightened up carefully although a fail to understand how one is expected to get any kind of torque wrench on any of the nuts; but the rear ones? Come on, you have to joking! I would find out later that they had more humor in store for me!!
With the cylinder on and the head ready to go I prepped the copper gasket, fitted the new aluminium pushrod tubes and dropped the head over the studs. This bit was too easy - I must have done something wrong! The four Allen Bolts were then fitted from below. These are a bit difficult, but with a good amount of cursing the designers they were gently nipped up. Using Bryce's method of a copper washer and an 'O' Ring under a regular thick washer on the two center studs I put all the nuts on and progressively tightened the nuts to the recomended torque. Now it was time for the designers to have their last laugh! How the hell did they ever think you were supposed to get a torque wrench on the Allen bolts from below? Jokers . . Good job I have a carefull calibrated elbow. They are now perfectly torqued - the old fashioned way . .
So next steps are pushrods, rocker gear, carbs etc.
Hopefully this comming weekend I'll be able to get out to the garage for a while and report more progress.
Ian
