ianashdown
The Paint on the Cylinder, Head and Rocker Covers of this engine was not very pretty. It had flaked off in areas and was generally just not good, so as part of the top end rebuild I decided it would get repainted. I took all these parts to a new Vapor Blast shop in Anaheim, but it appears that Vapor Blasting is so gentle that it doesn't even remove paint! Well it will, but it takes a very long time and if you're paying for it it would get very expensive! He did show me the effect in one small area and the result is very nice indeed. I think this is a good process for non-painted castings etc.
So; Plan B. I ordered two differend grades of Walnut Shells to use in the blast cabinet. I tried the larger ones (size 12-20) on the Rocker Covers last night and the results are quite good.
![DSC01155.jpg DSC01155.jpg](https://cdn.imagearchive.com/triumphtalk/data/attachments/10/10973-9ae74000dc378f983baba9d7558a455c.jpg?hash=mudAANw3j5)
![DSC01156.jpg DSC01156.jpg](https://cdn.imagearchive.com/triumphtalk/data/attachments/10/10974-6e58ef37fbe38d901f686b9d9be8b0cd.jpg?hash=bljvN_vjjZ)
![DSC01157.jpg DSC01157.jpg](https://cdn.imagearchive.com/triumphtalk/data/attachments/10/10975-8cd01514616c37ce4ccad3b92079db9b.jpg?hash=jNAVFGFsN8)
Given that I'm repainting these I don't have to get 100% of the paint off, and these larger pieces of shell didn't get in to some of the tight areas very well, but they take the paint off very nicely and leave the casting vertually changed. They are very gentle. I think the smaller grade might get in to tighter areas a little better. Overall a great success I'd say. It's not fast, and I have alocated all of Sunday to clean the Head and Cylinder. We'll see how I do!
I also tried using the walnut shells to strip paint of some fiberglass. You have to turn the pressure down to about 40 psi (ask me how I know), but it worked so well you can almost strip it coat by coat. Very cool!
35 Days to go!
35 Days to go!
