Depends what is inside the "modern Hella 7-inch headlight":-A Triumph TT special built for a top sound designer
under the ‘Lucas’ cover is a modern Hella 7-inch headlight. (“It’s nice to be able to see, and they don’t draw much power.”)"
hoping/thinking I might be able to do something similar
. If it is an incandescent bulb, it only "don’t draw much power” if it is a lower Watts. But then it produces less light ...
. The only way for it to draw less power but produce more light is if it is LED. However, that slim (from the side on photos on the original webpage), it can only be a complete LED headlamp, not a LED bulb in a reflector/lens intended for an incandescent bulb.
Do not discount the possibility the webpage author simply does not know what he is talking about. Electrics are magic to some even in the First World ...
Another thing to remember is that bike is in CA, where I know it does not rain much; otoh, you are in VA, where it does? I appreciate you might not be intending to ride in the rain but I am guessing it is not to difficult to get caught in rain when your are out and/or have to ride on wet roads? Even if you don't want to mount switch, idiot lights and/or gauge in the headlamp shell like Lucas and Triumph did on your bike originally, the shell is a useful place to shelter connections for other electrics in that area; you hardly want your bike stuttering to a halt just because the road was wet and spray got into an electrical connection under the tank?
