the intake and exhaust camwheels are the same part, with identical marks. later T140s used letters instead of dots and i dont know about them. but the earlier ones in yours are easy.
the stock camwheel mark is the one on the rim, near the teeth. some nervous nellie added your extra punchmarks near the keyway. that keyway -- the one in line with the punchmark on the rim-- is the one you use to fit your camshafts into the stock position. it should be okay as-is.
you can advance or retard the timing of your camshafts in 4.8-degree increments by holding the camwheels still (conceptually) and rotating the camshaft CCW to retard or CW to advance one keyway at a time. if you choose to do this:
-- you must check the cam timing with a degree wheel to set the camwheels to the correct position at the new timing.
-- the marks on the camwheels will then no longer line up on the idler and you must paint new ones
-- you MUST check the valve to piston clearances and the valve-to-valve interference, as everything will have changed.
but theres no reason to mess with camshaft timing unless youre looking for something very specifically non-stock, so this is just a heads-up.
this is one where i use a different cam timing and had to paint new marks
