You could try, but it looks pretty bad. The shaft and the sleeve it rides in need to be VERY straight or you could suffer a brake lock-up at speed. I think you can find decent replacements used on e-bay.When taking apart the rear wheel today I found that the brake plate was bent. I’m wondering if anyone has experience with this sort of damage. Would it be possible for me to attempt to bend this back into shape?
Yes, I'll get it all apart and see what other damage there might be.You could try, but it looks pretty bad. The shaft and the sleeve it rides in need to be VERY straight or you could suffer a brake lock-up at speed. I think you can find decent replacements used on e-bay.
Yes, that is what I am finding as I'm looking for options.New parts aren't as expensive as different forks that are easily adaptable, in near-new condition.
Those springs are yellow-green from what I see
Monobloc Carburetters - Carburetter type number e.g 376 or 389, followed by size designation.Hi,
I am new to the forum. I’ve some experience with motorcycles, first Bultaco Pursangs in the 1970’s, then on to BMW bikes. I had a K75S and rebuilt most of it. Then onto a K1300S, perfect shape and very fast and smooth - passed on to another rider in 2019.
I’m in the northern part of Virgina, in the USA.
Now those have gone and I’ve recently acquired a Triumph T120R. The bike is a 1967 T120R Bonneville frame (DU49062) and the engine from a 1969 T120R (EC 19971). It has been in storage for the past 30 years or so. It was rebuilt in about 1982, with a Routt 800cc big barrel kit. Apparently it wasn’t ridden much after then, the owner being in the military and moving around a bit while the bike was in storage.
So I am trying to decide how to best approach this beast. The Amal monobloc dual carburetors are off the bike, and they have the numbers of “10 66” and “389/95” written on the intake flanges. So I am wondering where to get a rebuild kit for these carburetors - or perhaps new carburetors?
Since the bike was rebuilt in 1982 and not ridden much after, I was thinking of just trying to rebuild the carbs and install them and do a good change of oil and fluids and such and trying to give the bike a go - that is see if I can get it running.
The gas tank is rusted out so I need a new tank. I was looking for something simple, and saw some of the tanks for sale on eBay from India. I’ve heard these are not so great. Although I see they also have an alloy/aluminun tank that looks pretty nice.
I am not trying to restore this bike, but just get it running and ridable - with a look to it being a bit more of a scrambler/desert sled style.
So I am wondering if any of you might know the provenance of the carburetors and/or where to get a rebuild kit for them. Also, any suggestions or a replacement gas tank?
Thanks for any advice. I imagine this forum has a number of threads that will have some great information. I will appreciate any of you having some advice or suggestions about the best places to go for parts and information.
Thank you!
Serge, thank you for the information. I am still needing to get new carburettors. I am putting my engine back together again and will need some in a month or so. Thank you for your advice!Monobloc Carburetters - Carburetter type number e.g 376 or 389, followed by size designation.
376 series, size designations are: 1516 for 15/16" bore diameter, 1616 for 1" bore diameter and 1716 for 1 1/16" bore diameter.
389 series, size designations are: 3632 for 1 1/8" bore diameter, 3732 for 1 1/16" bore diameter. Both series are only available in right hand adjuster form, 'Short' float bowl versions ('S' designation) are available.
I putted new ones and the result is fabulous, There are some on Amal Carbs 389/95 Triumph T120c 1966 T120tt 1965-66 for sale online | eBay
Ikon shocks.I’m getting to the point where I need to get some new shocks. As this is a scrambler type of build, I wondering if there might be some recommendations from the forum. I’ve looked at several types: Koni dial a rides, Girling type 13.4”, Hagon premium shocks. The Hagons are more than twice as much as the the others. I’d appreciate any advice on the matter. Thanks!
Got it!Ikon shocks.
I would lightly dress both the case(s) and the rod bolts EVER SO SLIGHTLY.In addition to my concern about the crank’s freedom of movement, I noticed that every once in awhile the left rod stuck slightly at the same place. It didn’t happen all the time but when it did it was at the same place... So at this point I may need to get my Dremel out and take a bit of the edge of these rod bolts off. While I just have them sticking at one point I should probably grind polish each of them because I wonder if when the engine heats up and expands there could potentially be more rubbing.
I was careful with the rod and rod cap orientation so I'm sure it is as it was. It turns freely on the crank - made sure to check this before assembly. So I'm pretty sure it is this slight contact with the rod bolt head. Crazy.I would lightly dress both the case(s) and the rod bolts EVER SO SLIGHTLY.
Does the rod have the same stiction when the crank is OUT of the cases? If so, you need to disassemble it off the crank and look for where the interference is on the shell-to-journal contact patch. Remember not to mix the rod & cap orientation up...
