I have a '77 T140V that I purchased a little more than a year ago. The previous owner had went over everything mechanically and replaced most hoses, gaskets, seals, and fluids. My first oil change was last fall and I drained the oil from the drain plug in the sump; the oil was in rather good condition so I did not bother removing the plate. I refilled the tank, started it up, and checked that I was getting return oil, which I was.
I just changed my oil for the second time yesterday, drained from the plug, removed the plate, removed the filter (which was damaged and I did not replace). I made a new gasket and reinstalled the sump plate. I then drained the small amount of oil from the engine, checked the filter (which was perfectly clear), and replaced. Finally I changed the cartridge type filter that the previous owner had installed on the bike. I then refilled the tank, kicked it over a few times, and started it up for a couple minutes. The oil return spit out a small amount of oil then proceeded to pump out air bubbles. I shut off the bike, primed the sump by pouring 200cc (roughly) through the rocker cover, and started it back up. The bike pumped oil until those 200cc were used up and then proceeded to blow air/oil bubbles again. I did ride it around the block once to see if that would help get the oil moving and pumping, no such luck.
Currently I have a oil pressure light on when the bike is running and the pump is only pumping air. I am at a loss as my knowledge has been exhausted, any help is greatly appreciated. Obviously I am not running or riding the bike at the moment.
