AHA! The spring is from the seal lip (crankshaft seal).
The puller point can bear on the crank stud nose.
Thanks for the tip. I will give this a try, gently that is. Perhaps I will need a puller later on in the rebuild?
Thanks grandpaul. I suppose then this is nothing serious to worry about - although I suppose if the seal was compromised it may have had some impact on the engine. I've yet to try again to get the rotor off but will soon.AHA! The spring is from the seal lip (crankshaft seal).
I will give it a try with a couple of pry bars and then go to a puller if needed. I bought a puller for the engine and gearbox sprockets from Lowbrow - hope to use is very soon.a puller is always useful, but ive never had to do more with a rotor than wiggle it off with two pry bars.
but its possible that somebody stuck it on with red loctite, and that always changes the game. sometimes people weld them on. thats the worst case
you csn use a two jaw puller on the engine and gearbox sprockets, but its better to just to drill three holes in a piece of steel, thread the middle one for a bolt and make a puller that draws the sprocket off using the threaded holes in its side
OK, I'm not familiar with what "runout" is in this case. Is this something then that will have to be accomplished on assembly or is there some other way? On the fork roller, yes, I see now. Since this was the last thing I took off I can see why I wasn't sure of its origin. (cross posting)Too late now, but I would have left the cams and pinions in place and checked for runout, then NOT TOUCHED them unless it was excessive, checked against allowable spec.
That is one of two fork rollers that go on the little pins of the fork; they ride in the gearchange camplate slots.
(diggin' this cross-posting trip)
dont try to take out the camshaft bearings. they last forever and yours are probably fine.OK, I'm not familiar with what "runout" is in this case. Is this something then that will have to be accomplished on assembly or is there some other way? On the fork roller, yes, I see now. Since this was the last thing I took off I can see why I wasn't sure of its origin. (cross posting)
OK, thanks for the advice. I think I heard something about that. There must be some way to determine if the are OK?dont try to take out the camshaft bearings. they last forever and yours are probably fine.
If you look in a 69 650 parts book, "CRANKSHAFT AND CONNECTING RODS" pages, the drive end of the crank should be exactly the same as 67 - "the long shouldered nut" securing the rotor (part #25) should screw on to stud #7, the other end of the stud screws into the end of the crank.I removed the long shouldered nut from the rotor and this is how it was.
Here is a photo prior to removing the nut on the rotor.
I was initially stalled by the rotor, but was able to get a 3 jaw puller to get it off.
I would not bother. The "6 68" indicates it was made in week 6 of 1968. It should have been a sliding fit on the crankshaft, although the gouges on the crank's rotor mounting area might have had something to do with the removal difficulty. You have pulled on the outside of the rotor to extract it. In the grand scheme of what you are spending on this engine, a new rotor is not expensive.Test your alternator rotor for looseness-
You are mistaken, enter "triumph 70-6061" into an internet search engine, look at the returned images to see what a new one looks like.
Or the wrong thread puller was used? 69 'should' be 5/16"-24 (UNF), if the engine builder used an earlier one, the thread would have been 5/16"-26 (Cycle).I had some difficulty getting the advance off as the interior threads would not take my puller.
advance
should probably be replaced.
Points and mechanical AAU are a crude way of making and timing an ignition spark, even if the springs have good tension. Otoh, electronic ignition for these bikes has been around for half a century.The AAU is still re-usable, as long as the springs have good tension
OK, so this, like the head, is going to be best left to an expert. Once I've gotten it figured out what barrels I will use and then the appropriate pistons, etc, I should find someone who can dynamic balance this crank.Your crank was Dynamically balanced MOST LIKELY (no way to be sure, unless you can track down the etched number that was likely put there by the party that balanced the crank).
The balancer clamps the appropriate weights to the journals to represent the rods & pistons' weight, then the entire affair is balanced. Better than static balancing, and most likely was used when you consider all the other parts you have there.
If you have to re-bore, you'll need to replace anyway, and likely a re-balance would be in order unless you can SOMEHOW match larger pistons' weight to the existing pistons.
oil pump
nuts securing this were lock nuts without washers.
+1.pitch those nylocs in the bin. the right nuts and washers cost nothing, and really the oil pump was not the place for your PO to get creative.
Thanks for the detail on getting the pump aligned properly! I have considered a new pump. You are referring to their plunger pump or the rotary pump? I've heard from some that too much pressure might be a bad thing - but it seems this would be much better for the engine.
+1.
All holes in components that either fit over studs or take bolts must have a little clearance around the stud/bolt. However, particularly the oil pump also has feed and scavenge holes that must line up exactly with corresponding holes in the crankcase, the clearance in the mounting holes cannot be allowed to misalign the feed and scavenge holes even a little. The correct pump securing nuts have a convex surface on one side, two screwed equally into the concaves around the pump mounting holes should centre the pump feed and scavenge holes over the ones in the crankcase. Standard engineering solution afaik.
Depending on your budget, have you considered a new Morgo pump? Based on the later 4-valve pump and with a little extra oil volume.
Morgo also do the hemi nuts and spring washers; they unhelpfully list "T140" and "T120" when the actual difference is respectively UNF (1/4"-28) and BSC (1/4"-26); certainly according to the '69 650 parts book, your nuts should be UNF.
