I used to use a beam one, it got lost among many moves. I replaced it with two “click” type. Been pretty happy with both. Also store them in original container and zero after each use.
I started out with a beam-type of torque wrench, but later bought two click/break-type wrenches; one to use in inch pounds and the other in foot pounds. They are handled carefully, always and returned to zero and stored in their cases.I used to use a beam one, it got lost among many moves. I replaced it with two “click” type. Been pretty happy with both. Also store them in original container and zero after each use.
Got it. Thanks!I would first confirm the hardness of the cams and followers.
If not hardened to 69 or later spec (Nitrided), you'll need to re-open your oilway and get drilled cam followers.
I'd be concerned enough with this one to call Megacycle and ask their opinion. Send them a copy of both photos......upon further examination of my cams I found some pitting. On the exhaust is a large pit on the lobe... I’d be interested in knowing if these pits are a serious concern?
Hi, I've started a rebuild of a t120 tr6, i got a full, carb kit from cheshire classic bike parts, ask for peter, a really nice guy,Good luckHi,
I am new to the forum. I’ve some experience with motorcycles, first Bultaco Pursangs in the 1970’s, then on to BMW bikes. I had a K75S and rebuilt most of it. Then onto a K1300S, perfect shape and very fast and smooth - passed on to another rider in 2019.
I’m in the northern part of Virgina, in the USA.
Now those have gone and I’ve recently acquired a Triumph T120R. The bike is a 1967 T120R Bonneville frame (DU49062) and the engine from a 1969 T120R (EC 19971). It has been in storage for the past 30 years or so. It was rebuilt in about 1982, with a Routt 800cc big barrel kit. Apparently it wasn’t ridden much after then, the owner being in the military and moving around a bit while the bike was in storage.
So I am trying to decide how to best approach this beast. The Amal monobloc dual carburetors are off the bike, and they have the numbers of “10 66” and “389/95” written on the intake flanges. So I am wondering where to get a rebuild kit for these carburetors - or perhaps new carburetors?
Since the bike was rebuilt in 1982 and not ridden much after, I was thinking of just trying to rebuild the carbs and install them and do a good change of oil and fluids and such and trying to give the bike a go - that is see if I can get it running.
The gas tank is rusted out so I need a new tank. I was looking for something simple, and saw some of the tanks for sale on eBay from India. I’ve heard these are not so great. Although I see they also have an alloy/aluminun tank that looks pretty nice.
I am not trying to restore this bike, but just get it running and ridable - with a look to it being a bit more of a scrambler/desert sled style.
So I am wondering if any of you might know the provenance of the carburetors and/or where to get a rebuild kit for them. Also, any suggestions or a replacement gas tank?
Thanks for any advice. I imagine this forum has a number of threads that will have some great information. I will appreciate any of you having some advice or suggestions about the best places to go for parts and information.
Thank you!
Hey, thanks for the information. I'll check this out. I was thinking of going with the Amal or Mikuni. Once I get a bit more along with the engine reassemble I'll figure out what carbs I'll use. Cheers!Hi, I've started a rebuild of a t120 tr6, i got a full, carb kit from cheshire classic bike parts, ask for peter, a really nice guy,Good luck
Yeah, that is at the top of my list.If you are going to have to pay for a new carb or carbs, may as well buy Burlen Amal Premiers.
Thanks grandpaul. I imagine that this has been run with it like it is. It does not seem like damage or wear. So it doesn't seem like there would be a safety or longevity issue with the way it is, perhaps a performance issue since it might impact exhaust flow a bit. I'm considering leaving it as it is if this is the case. I've got to think others have seen this exact defect.That's very common. I've heard of using a liquid high-temp epoxy and using a vacuum sealer to draw it in (not exactly sure how that works).
Anyway, I've also heard of the 2-part clear JB Weld applied to VERY clean and dressed gap all the way around, then dress with a Dremel emery-tipped tool after it cures. Set the head where the JB Weld can creep downward as it cures.
