Just googled, there seems to be plenty of 35 mm clip on bars available. Seems the biggest obstacle is how much one wants to pay.
Absolutely a point on the bicycle riding position. I’ve done a fair amount of riding in a forward position and think that may be one reason I’m pretty comfortable on my Thruxton.Yeah, I've found several models on Scamazon machined from 6061-T6 aluminum without bars in the $20s and with in the $30s. The chief benefit of the Woodcraft seems to be it's machined in halves, so one doesn't have to R&R the fork tubes to install them--but that's a minor issue for me, as the bike isn't yet running. It's going to be hard for me to justify paying $200 for a name brand if I like the fit and finish of options like I've seen...
As for the issue of a more aggressive riding posture, two things: first, I've already got a more or less upright vintage cruiser in the '51 FL (see 1st pic) and don't want another; second, I hadn't thought about it but I'm actually used to riding for extended periods of time in such a posture (see 2nd pic). Now, that's a bit different because you're pedaling, in and out of the saddle, etc., but still.
At any rate, I've got the flat bar at the ready for whenever the fairing gets here, and am eager to experiment. Then there's the issue of the seat height--but again, I want a two-up seat for a passenger and for my soft tail trunk.
You can always upgrade later if needed, but the inexpensive ones will let you get the setup together.Here are: just the clamps for $21 (I could use the ends of my existing flat bar); and no-rise and 1" rise options for $38 each. All of this stuff is available in black, which would match the triple clamps, but silver is cool, too...
Having done what you are doing many years ago, your thread does not have enough thought given to footrest position (I have expressed it that way in case you have given it more thought than you have posted) ... Ime, standard Triumph rider's footrests position is much too far forward for anything but standard US bars; standard footrests were horribly uncomfortable even with standard "UK & General Export" bars.rear-sets if I felt that pegs needed to shift backward a bit
Aside, strictly speaking, they are not, they are "swan-necks" - while they mount on fork legs between upper and lower yokes like clip-ons, clip-ons keep the rider's hands below the upper yoke (Hinckley's appreciation of Triumph and British motorcycling history is generally poorMy Thuxton has clip-ons
While I am spending your money, consider Norman Hyde "M Bars"? As Norman intended them, they have about a 1" rise between the mounting and the ends; flipped over, this obviously becomes a ~1" drop ...still holding out a faint hope that I'll be able to use my P-clamps and a single bar.
The mounts might well not be reusable if you have spent enough time mounting the fairing on your bike well enough to prevent the vibration damaging the aluminium - British singles' and twins' vibration splits and cracks steel fenders, never mind aluminium, fibreglass, etc.; you will be very pissed indeed if anything similar happens to the fairing ...?if I decide not to use it once in-hand, I could always sell it to a 'modern' Bonneville owner here in the states, as that's the bike for which the mounts are configured (and which I'd modify if fitting it to my bike). So, I wouldn't be out a dime.
Do the steel gauge mounts not have "notches" to engage specific parts of the gauge rubbers? That would then prevent the gauges being realigned in the pivoted mounts?pivot the gauge mounts inward (we'll see whether I want to make up a custom aluminum dash
Mounting plastic parts, I have adopted the system I found on Japanese bikes - hole in the plastic part for a grommet, steel bush in the centre of the grommet that is slightly longer than the thickness of the grommet. The bush then allows the mounting fastener to be done up tightly but will not allow the tight fastener to compress the grommet, grommet isolates the plastic part from the fastener's head, nut, washers and from the bush with the fastener through it. The Japanese size the hole in the plastic part quite closely to the o.d. of the middle of the grommet so there is little or no sideways movement of the plastic part.The Omega mounts have a rubber pad between the clamping surface and the steering neck, with U-bolts hooking around
Good idea, though, to think about incorporating rubber pads wherever I can without the fairing flopping around at speed;
If you try these, ime pay the money for adjustables. I have never tried the fixed ones but read many posts on various forum where posters could not find a comfortable hand position, ended up discarding them. My adjustables came from a long-gone'clubman' bars
aluminum sheet
custom dash
Covering the engine covers just adds extra work if you need to access anything for maintenance. Cool is nice, but I like the idea of not adding extra work without good reason.So, I changed my mind: I'm ordering a set of non-crossover pipes made by LF Harris (made in UK) from Kyle Jones. I've done a bunch more reading, and numerous engine tuners and racers seem to agree that so long as one is dispensing with the OEM airbox and mufflers, there's no particular benefit to retaining the crossover...
...other than noise reduction. That's not a big consideration for me. With the Dunstall replicas I'm 99% sure I'll be fitting after re-wrapping the cores with better insulation, and based on the Lemon Drizzle Gang's video of Dave's 750 with the identical mufflers, the exhaust note shouldn't be excessive.
The only other muffler I like after doing some more looking and listening is the Gold Star style many people fit to cafe bikes--which I think is a straight-through design, but the tapered megaphone really looks nice on this bike. Perhaps the fairing's looks will change this leaning but I don't think so...
Part of me wants to go with the swept-back style that many people upgrade sporting bikes with, but I don't like the idea of the engine covers being covered by the pipes. I also think the sweep of the stock-bend pipes looks great.
For old Triumphs, ime the best are Triples Rule 2-gauge bracket or 3-gauge bracket - simply bolt on, hold speedo and tacho in the standard 71-78 rubber cups. He (Pat Brown) makes them for forks with stanchions 6-3/4" apart as on your bike.if you’re looking for a lay flat instrument panel
Originally, British racers made them that way because, when braking and cornering hard, the bottom front curve of a standard pipe can touch down. Riding on public roads, do you think you might lean over that far when also braking?Part of me wants to go with the swept-back style that many people upgrade sporting bikes with
Conceptually if it’s lay flat it should work. You’ll get a better idea as you look at the rough attached fairing. It’ll give you an idea what needs modifying. I had to put in a different brake fluid reservoir. I didn’t find the one that would be ideal, but worked. Still looking for a better solution.
