Well, I'm a little behind the curve due to other commitments, but hope to get the tire fitted and wheel mounted this weekend. I had a go at it yesterday but was having trouble with the Battlax's bead and didn't want to bugger up my shiny aluminum rim, so am taking it to a shop this a.m.
I'll post some pics--and will be able to provide an unsprung weight comparison: caliper is 29 oz, and will have to be added to built wheel weight (plus axle) to net a 1:1 comparison to stock, which is 31 lbs.
In the interim, while looking at an earlier post, I realized that someone wanting to do this conversion as a straight bolt-on (i.e., without having to lace up a wheel) could just buy a new (or used) 19" x 2.15" front Sportster wheel. Chrome steel (aluminum hub) is available for $170~$250, depending on vendor.
I haven't (yet) found a built wheel with an aluminum rim fitted to the second-generation hub used on this conversion, so the concession would be more unsprung weight. My goal, in case it wasn't obvious, was to increase braking force without overwhelming the dampening specs of the OEM Triumph sliders. We'll soon see if I was successful!
