speedrattle
the GT style is the next best thing to the old donkey dicks.
i use em on everything
Both ends of the T1736 clutch pushrod are (should be) hardened (something that has to be redone if a rod is shortened).doesn't explain why neither of the pushrod's ends gets destroyed when it is shoved against the clutch pressure plate, which presumably is spinning away.
When the Triumph multiplate clutch is adjusted, is why you have to tighten the T2159 "Adjuster pin" in the the centre of the pressure plate very carefully, so that the play between the various clutch actuation parts is just taken up; then, when the Adjuster pin is turned anti-clockwise half a turn or so, that gives a small amount of play between the normally spinning clutch and the not normally spinning pushrod.
When the clutch is operated and the rod is pushed against the Adjuster pin in the pressure plate, the Adjuster pin should spin only briefly on the hardened end of the pushrod, because the pressure plate stops spinning. The Adjuster pin will spin longer on the pushrod when pulling away from a standstill but, as long as that is not excessive, the Triumph parts seem to work well, last a long time.
A mod I have known some twin owners make is cut a clutch pushrod half, shorten the two halves to accommodate a small bearing ball in the mainshaft between the two parts of the pushrod.
i once welded both ends solid pulling in the clutch and holding it at the end of a dyno run. my mistake, not the fault of the design.
i cover the pushrod in white lithium grease too before i slip it into the mainshaft, just in case things do spin. even after a hundred miles or so the grease is still there.
Only better if the length of thread on the plug is more like the length of thread in the crankcase. If more, it is just metal protruding inside the crankcase towards a spinning gear ...tranny drain plug and level tube
better
threads are slightly longer.
Yes (I know); no longer one - the latest 750 twin manuals readable online are '78 T140E Owner's Handbook and '73-'78 750 twin workshop manual, both have the same 500 cc gearbox oil quantity as your bike. If you put in much more, when you lean the bike on the sidestand, gearbox oil runs out over the gearbox sprocket ...length is substantially longer. Does anyone know if the longer tube superseded the OEM shorter one?
Having a lengthy association with Triumphs, I regard the drain plug with the level tube as the devil's invention - having seen too many tubes rolling around in the bottoms of gearboxes and one set of crankcases where the loose level tube had been picked up between two gears ... I do not know whether that bike's rider survived.
Regrettably, the 650/750 twins are the only Triumphs that did not get a gearbox cover modified for a dipstick, a standard bolt substituted for the level tube drain plug. Nevertheless, for the above reasons, I would never use a level tube drain plug (particularly one possibly as badly made as your new one). The gearbox oil quantity is 500 cc (here, that is a standard bottle of gearbox oil); I do not know anyone who does not have a measuring container of some sort in their garages, workshops, sheds; if I tip the correct measured oil quantity into a gearbox, why would I need that horrible level tube? I can see if any oil subsequently leaks out; if I am concerned about the gearbox oil level, it is not difficult to drain it into the measuring container to check?
More subtle than that ...For the axle on this conversion, since the
Triumph disc brake sliders
take a 3/4" O.D. spindle, one could either buy a later model T140 axle
While the conical hub spindle takes two W653/37-0653 bearings, disc brake spindle takes only one, and they are nominal 20 mm i.d. bearings (the bearing i.d. is slightly smaller, the spindle o.d. is slightly larger.
Between where the bearing fits on the spindle and the end of the spindle is slightly smaller than the bearing i.d. but is still larger than 3/4" (I measure 0.780"/0.785").
The 57-1070 captive bearing on a Triumph disc brake spindle is 25 mm i.d. nominal.
The "shoulder" on all Triumph spindles is for the captive bearing inner race to bear against.
thankfully, this is less complicated, as the Sportster hub (for this year range) just has two bearings pressed in from each side against a central tubular spacer.
Given all the other work you do yourself, surprised you do not make it yourself? I have made my own braided brake hoses for years, using Goodridge stainless parts, very simple, very foolproof, very long lasting.order a brake hose.
