Given all the other work you do yourself, surprised you do not make it yourself? I have made my own braided brake hoses for years, using Goodridge stainless parts, very simple, very foolproof, very long lasting.Happy to suggest Goodridge and standard Triumph parts to use, if you wish?
Sounds like great minds think alike.
My 17-year-old nephew was in town and wanted to help, so I got the metalastic bushes for the handlebar pressed into the triple clamp (took some fiddling, but in they went), installed headset bearings, the P-clamps and handlebar, headlamp rubbers and nifty LED bulb, and brake master cylinder.
The bars are a bit 'floppy' with the metalastic bushes, but I assume that means the vibration isolation design is working properly...? With the new headset bearings properly adjusted, the steering action is effortless and smooth, so I don't imagine much leverage will be needed to steer this light bike.
I've heard dissatisfied murmurs about that funky headlight bracketry, but with new rubbers and the 'C' shaped washers, it actually holds the OEM headlamp housing adjustment very firmly.
Slipped the tank back in place, so I no longer have to worry about it getting dented. It's starting to look like a motorcycle again...
