Sorry, I didn't see this post of yours earlier.
Guy I know has a 3-gauge bracket - speedo to tacho centres 6-1/4", speedo and tacho centres to (disc brake) stanchion centres 3-3/4" (disc brake stanchion centres 7-5/8").
Regrettably, Pat Brown made the bracket to take a 1-1/2" nominal pressure gauge, that guy I know has not been able to find one with a light.
While today modifying a gauge with an LED could be possible, when he first fitted his, he modified a standard Triumph pressure switch to use as a banjo bolt to clamp the gauge hose while retaining the warning light.
Some pressure switches are made with a 1/2" o.d. section between hex. and thread, that happens to be about the same width as a Goodridge 3/8"/M10 i.d. banjo; he machined the 1/2" o.d. down to the same diameter as the switch thread, cross drilled it.
Fwiw, this also averts the other problem fitting modern oil pressure gauges to old Triumphs - apart from early triples, BSA/Triumph used 1/8"NPS-thread pressure switches - if you did not know already, specifically NPS-thread fittings are virtually unobtainable today.
NPT-thread are easy but, because Triumph left twins' timing covers very thin around the pressure switch hole, they are very easy to crack with many NPT thread male fittings.
