Like you I was looking for a magnetic sump plug for my bike (73 TR7RV) with no luck. Someone has suggested that I buy a small Neodymium magnetic from Amazon and drill a hole in the end of the standard plug to hold it. No glue is required as the magnetic force will hold it in place, although I think I will probably add some JB Weld.I have yet to find one. Does any know of a magnetic oil drain plug for the Bonnie SE/T100/T120 motorcycles?
I had one in my DR650. I would like to find one for the Bonnie.
On my last bike....I stuck 2 of those magnets on the the outside of the plug....should magnetise the hole plug then.Like you I was looking for a magnetic sump plug for my bike (73 TR7RV) with no luck. Someone has suggested that I buy a small Neodymium magnetic from Amazon and drill a hole in the end of the standard plug to hold it. No glue is required as the magnetic force will hold it in place, although I think I will probably add some JB Weld.
