Frank's Triumph 750 engine overhaul & resto-mod
Ok...Good News... I was able to get her running!!!
I Installed a temporary Gas tank (aluminum water bottle) that I had from my previous build. I did a rough wiring job, Just the basics to get her running.
I must have kicked it about 40 times and nothing( have about 20+ minutes of video), I had to double check all my wiring and tested to see if I had Spark... and NO, I did not.
Please note I am not running a battery, because I'm using the Sparx rectifier/regulator/battery eliminator box. Wiring looked ok, so just as I was about to call it a night, I decided to connect my sears battery charger into the wiring. tested for spark and yes I go spark... Installed the spark plug and on the second kick she turned on... For about 10 seconds, The Bike move in reverse and the charger got disconnected and she died. Then I noticed I forgot to turn on the camera... Darn. So I set it up again, this time with a piece of wood to stop her form rolling back. And here is the video of that event. Also note I forgot to open the fuel valve on the temporary tank, and yes need to adjust the idle speed
[video=youtube_share;y3T19ZeN_48]http://youtu.be/y3T19ZeN_48[/video]
Al though I am very happy I finally turned On, I till need to Figure out what is going on with my electrical.
I searched all over and could not find anyone with a Diagram using Sparx Battery eliminator and Sparx Electric Ignition. So I put together this diagram:
Paul,
the oil started to return right away, provably helped that I kicked it so many time before it turn on.
The bike dies right away if I disconnect the Charger... Need to check the new Alternator, I plan to put a multi-meter on the Alternator wires to see how much Voltage(AC) its producing. if that's OK then its got to be the battery eliminator box, not sure how to test it.
So 3 weeks ago I rough wired the Bike to get her started for the first time... I could only get her to fire up and kept her running only of I Hooked her up t my battery charger. I did some tests and determined that I was not getting any power out of the Alternator....
So finally yesterday I opened up the left side engine cover to see if there was anything the was obviously wrong.
And yes I found the problem, the wires were pinched by the cover, and are shorted.
Here I,m pointing at the area of the cover that pressed upon the wires, and shorted them.
Not sure if I can fix this or if I need to replace the stator. At least now I know what the problem is and that it can be resolved.
Update, while we wait for the new alternator. I got the tank Painted.
At the last minute I decided on a paint scheme... I had the Tank painted here locally with satin black. I then shipped it to a Painter in New Brawnsfels, TX (mikeyspinstriping.com) to get a hand painted logo and some nice pinstriping on the top. A couple of emails and he was able to get my "Vision" for the Tank. I shipped it out on Wednesday, and today I got a text from him with Pics, I am extremely happy with the results cant wait to get it back from him next week, and see it on the bike.
