I rebored my Trophy 500, stripped the motor down and gave it a general reconditioning.
It has good compressions (approx. 160 psi) and now runs well. It has a new oil pump and seals throughout. The oil return has good flow to the oil tank. It has the later type of breather system without a crankcase seal on the left side and the breather from the primary chaincase.
However, it has a problem on standing for any length of time. After starting, it coughs out smoke from both exhausts for several minutes and then clears up. By the time it is warm the exhausts are both clear. The smoke is way more than you would expect from valve guide wear.
If I drain the residual oil from the crankcase before starting, there is no smoke. The amount of oil draining from the lower case is 160 -180 ml. Does this seem excessive?
I am guessing there is sufficient oil in the case that it must be contacting the crankshaft and being flung up into the bores and overcoming the rings.
Has anyone encountered this before and have any suggestions as to what might be the cause and/or cure for this?
Cheers, Bob Elwin
Cheers, Bob Elwin
