01 Triumph Bonneville Carbs
I rebuilt mine, but don’t recall if I replaced the screens. There are universal ones that might fit if you don’t find the one Triumph used. I’d have to see if I can find something on what the valve looked like. Might have posted it here. But I think there was on longer brass tube and a short one where the filters attached. I don’t recall if it was just a press fit with the filters. It won’t matter how long they are, both can be the same. I’ll see if I can find the link on the filters.
Appreciate that!
See it's pretty bad. The inside of the tank is still pretty bad with rust on the bottom side walls.
That is nasty looking for sure. You may wind up having a radiator repair shop boil the tank out and coat the inside of the tank. I'd start with the electrolytic procedure 1st then improve on it going forward.
Good luck on sourcing the petcock and screens. When it is all said and done, you'll have a great Made in England, carbureted, 360 degree firing order, proper, air cooled classic.
I hadn't thought about a radiator shop. Just called my local one, turns out they do motorcycle tanks too. The 2 day vinegar soak really did great work, but the rust on the sides and bottom remain. If it was straight see through tank I could really get in it.
So it's 350 to get the tank Coated! Not cheap. And I don't think I can use the electrolysis method because of the baffles that would hit the eletrode
Here is where I'm at: The tank needs another vinegar soak. I think one more and it will be pretty much rust free. I have to order a new fuel tap. I will be breaking down the carbs soon. Gas apparently did go into the crankcase at some point when it was left stored. I will be doing a flush with cheap oil and a can of seafoam soon, maybe tomorrow. In reference to fork oil....do I really need to fully disassemble the forks just to change the fluid? Or can I just suck it out through the top caps? The seals are fine, but the bike is an 01 so I want to change it. I have a laundry list of maintenance procedures, including checking the valve clearance. If they need adjusting, I will for sure let the shop do it. Pulling the cams is more than I'm willing to trust myself with.
The fuel hose (T3620008) needs to be replaced on my bike. There's a little in line filter that doesn't seem to be available except for under a kawasaki part number (49019-1085). Would you guys have any objection to me using an in line k and n fuel filter instead? The small clear plastic ones. I'd have to cut a section of line to fit it but it would be easier to monitor as it got dirty.
Just thought I'd update yall on the progress. The bike is now put back together and runs great. I have taken the carbs off probably 4 times....but, that's the name of the game I guess. I pulled the jets out, cleaned everything, and found one of the ports was stopped up causing a lean condition. Replaced the carb bowl gaskets and installed new stainless hex head screws (top and bottom.) I changed the float needles, but the floats were fine. The upper diaphragms were also still good. My OEM in line fuel filter had deteriorated so I replaced it with Kawasaki 49019-1085.. I changed all 4 the intake rubbers and the fuel lines. I also had to replace the fuel petcock with a Pingel valve.
I still have lots to do, but the list is shrinking. I want to get a new chain and sprocket, even though mine is now cleaned, adjusted, and lubed. I need tires, mirrors (probably bar end style), and I need to finish detailing the chrome and rims. I've gone through the brakes, changed the brake fluid, put a new headlight bulb in (Silverstars.) I still need to check the valve clearance, but it should be fine. I also will probably have the fork fluid flushed, as it is over 20 years old. And lastly, I need to fix my OOOPS on the gas tank at a body shop.
You can change the fork fluid yourself. It requires you remove the fork legs from the triple tree. Before you pull them out be sure to unseat the top cap while it's in the triple tree. The key things are making sure the old oil is completely drained, that may require leaving the fork leg upside down for a day. No flush required. And proper oil level with fresh oil. If the specs provide a specific volume you can measure, pour in and then work the air out, or if it provides a level from the top you'll need a tool like in the provided video. The maintenance manual will have the oil specs.
View: https://youtu.be/fOgd83sOaNU
