Zard Cross Exhaust Fit + Air Box Eliminator
SimonB
Hi I have received my Zard cross 2 into 1 exhaust for my 2001 carb Bonnie, it didn't come with any gaskets do I just get the normal standard copper crush ring ones? Also I'm fitting an airbox eliminator kit, what jets etc would any of you recommend fitting (also fitting K&N filters), thanks, Simon.
I suggest that you start with 145 or 150 main jets and 42 pilot jets. Then do a dyno run with exhaust sniffer. Check your air/fuel ratio. That will tell you if you are too rich or too lean. You are better off a tad on the rich side than a tad on the lean side. Running lean causes excessive heat which is not good. Contact the folks who made the airbox elimination kit and see what they recommend for jetting.
