- Open the shed.
- Take the covering off the bike.
- Roll the bike down the small ramp onto the grass, this has to be done in reverse.
- Move the car as the only way out is through the carport.
- Open the front gate and get the bike onto the sidewalk.
- Close the gate.
- Get dressed into riding gear.
- Take the bike for a rid
Sounds you've got it easy.
Here's my ride process.
# open sliding patio door fully.
# go into garden, to small shed.
# from shed remove two large sheets of ply.
# move furniture around.
# in the lounge, do a multipoint turn on my bike, so back end is pointing towards open door.
# lay one piece of ply outside, one inside, so there's a double sided ramp going over the 6" high threshold.
# facing away from door, roll bike backwards. Enough momentum to get up ramp, and over the 1" mini threshold at ramp apex. To far to my right, I demolish the dining table. To far to the left, my bike crushes my into the door frame. I have to go backwards, only way for me and bike to get through the door. So getting the right momentum is crucial, as I have to be prepared to abort move.
# too fast through door, and I can't keep up with bike, it rolks away while I have to squeeze through small gap bike left by bike.
# bike and me end up on timber decking, that's lethal in wet weather, so I have to sort of walk a bit like jackboot marching. I'm doing this backwards too.
# in garden do a multipoint turn, rest bike on a brick.
# go in house and get garden gate key.
# open gate, prop open with an old front tyre.
# do a 180⁰ multipoint turn to get bike front end pointing towards gate.
# sit on bike and paddle between low brick wall and small tree, turning sharply, tucking my leg behind footrest so my leg isn't crushed.
# lock garden gate.
# go in house, get anything on needing, fetch helmet.
# push bike 50 yards to nearest road.
# hope it starts. Obviously entails the ol' tickle and pray rigmarole.
Reverse process either after the ride, or when it won't start.
Bike, door, threshold, decking, tree, gate, low wall, shed
