What I Did With My Bike Today
I downloaded the FREE Excel phone app.
Now won't have to scroll back through photos to find pics, my previous method of record keeping.
Have found last relevant photos and started it.
Works just like desktop Excel, except use finger. Desktop won't get switched on when I'm bike fiddling.
Amal MK1 carbs:
I swapped the rubber-tipped float needles for genuine 1970s all-nylon needles.
The difference is night and day!
Tickling, floods immediately, not three, four seconds. Since started first kick several times today, hot and cold.
Previously, one carb had an rubber -tipped aluminium needle, the other a rubber tipped brass needle. Was no difference between them.
Just shows, don't blindly believe the hype.
Also sealed float bowl gaskets with Hylomar Blue. No more weeping at gasket. Don't believe anyone doesn't get leaks here when riding at least, despite contrary strong assertions.
I spent yesterday diagnosing the reason my r/h grip heat isn't working on my 1200XE.
It would be nice if you could remove the grip to get access to the connector to check for power but noooo!!
You have to move the fuel tank back to get access to the connector on the other end of the cables, remove the cluth lever, remove the l/h mirror mount and remove the two plastic shields under the tank that protect the cables. Then you're ready to remove the l/h switch cluster for which you need a special Triumph tool. At least I was able to make my own tool after a bit of trial and error I got the cluster moved.
Then you have to disconnect the cables under the tank so you can feed enough back up to the bars and through the hole under the r/h bar to push the connectors out of the bars and disconnect the heated grips.
Now it's not possible to plug the cable back in under the tank, so you have to re-route the connector on the harness over the frame to get power to check for power at the grip connectors.
I had power at both ends so I know I need to replace the r/h grip. There isn't one in Canada so at least 4 weeks before I see that.
Meanwhile everything has to go back and in 4 weeks time I'll have to go through the entire process again.
At least I won't have to make another tool.
Rant over.
Note to Triumph - this design could be so much better / simpler!
Shows you've got a bike with heritage! Triumph heritage.
My first ever maintenance job was on a Triumph T14OE. The rear brake-disc slave cylinder needed replacing.
GrandPaul, member of staff here I think, I remember him posting: Triumph placed the slave cylinder in the middle of a room, and designed the bike around it.
I seriously learnt a lot on that first maintenance job. Could easily have been my last maintenance job too.
After I reassembled the whole rear end of the bike, I found I hadn't bled it properly (it's complicated). Booger that, I thought, I'm not taking the bike apart again. I rode around with just a front brake.
I won't now ride a classic bike older than 1974, think that's when the rear disc- brake was introduced. My project bike has the engine from that T14OE; I've converted the engine to RH shift so it can have a drum brake. Seemed easier than trying to bleed the brake when the time comes.
I've now made a second book to automatically calculate mpg. In the UK it's sold in litres.
The equation I made can be seen at the bottom. If anyone is interested, and struggling, I'll post a tutorial.
Remember, the app is free. Same file could be opened on a computer.
Keeping track of mpg can help notice any problems.
I will tidy it up a bit, only just done it.
The great thing is, fiddling with the app means I'm not actually using any fuel.
Edit.
Those are just figures I've entered to set it up. I actually get 60+mpg.
