bigdavewhit
They come undone anti-clockwise. They have a bayonet fitting so it’s like removing a light bulb. They feel tight but press them in as you turn. Refitting is the opposite but make sure they click fullyI've got some LED turn signal replacement bulbs(modules)for my 2022 t120 Bonneville and so far have had no luck trying to get the turn signal lenses removed.
Online says to just twist clockwise and off they come. I've got pretty strong hands and they don't budge. Another YouTube video
says to insert a screwdriver blade into the slot at the bottom of the unit and twist. That caused damage to the very cheap plastic
teardrop housing and also failed to remove the lens. Seems to be no info I can find out there. Any help would be appreciated. I don't
want to do any damage.
home. You’ll need to change the TYPE setting to 2 foe LED or the flash rate will be too high
