It looks good to me too.Looks good to go to me!
Posted from my Idea Tab using Tapatalk HD
I have one of those fitted to my '70 T100S. They generally don't come with a mounting bracket (some kits do; some kits don't) as you usually have to make one of your own to fit your particular situation.
For me, it was a lot of trial and error until I had a bracket shaped correctly so the filter cartridge would tuck up under the gearbox out of sight in the vertical position.
I do the same thingRocky, a good point about the vibration. I have found that when I have a vibration problem I use rubber grommets in the mounting hole to give some cushioning to reduce the vibration.
