When I got the T140, the previous owner had fitted an internal paper filter in the frame. At first I thought this was an improvement, but after reading a few articles on these filters, they are not as good as it first seems.
Because the filter is paper and fitted at the bottom of the frame, the oil pump has to suck the oil through the filter, this becomes more difficult as the filter becomes more blocked, especially when the oil is cold and thick.
Paper filter
So I removed it and fitted the Triumph 'top hat' filter in the frame instead.
I then fitted a cartridge type filter to the return oil line, this way the pump is pushing oil through the filter rather than pulling it.
It was a bit of a tight squeeze but using a 3" exhaust clamp and a bracket I made up, I managed to get fixed to the frame, tucked between the centre stand.
There was a LOT of EFFING going on during the process, but I am pleased with the result, when the exhaust is fitted the filter is totally hidden.
Paper filter
