Hoping for some assistance.
I'm now the owner of a Bonneville which needs a full going over, after having been left in the open for a number of years.
Rings and pistons have been replaced, but as the head is currently off, I'd like to lift off the barrels to replace the bottom gasket and fit new 12 point barrel to crankcase nut set.
While off I'll prepare and re paint the barrels.
ITEM 1: I need to clean out the heavily rusted threads of 10 barrel head bolt holes.
I'm having trouble screwing in the head bolts (by hand at this stage).
How should I go about cleaning out these threads?
So far I've applied a few sprays of wd40.
The barrel is marked, "BIR 001 71-3337"
If I use a tap die, is it 1/2in NF20?
ITEM 2: The drive chain was left out in the rain and has quite a bit of rust on it.
Naturally, after cleaning it, if there are signs of significant wear I'll bin it.
How should I go about cleaning it?
Should I place it in a bucket of petrol first, or maybe heavily spray it with WD40?
ITEM 3: I'm learning that gasket sets can come from a number of producers other than OEM parts.
Over here, it seems, choosing OEM involves selecting and paying for individually numbered parts.
I prefer getting a kit with a corresponding good price.
I came across, what appears to be good value, a complete gasket, o ring, and seal kit made in Taiwan from EMGO.
Are they all OK or should some be avoided?
Living in Australia, British items can be expensive, and U.S. items can have a very high postage cost.
Any recommendations for complete gasket kits?
ITEM 4: I find the Triumph Speed Twin motor a thing of beauty and the centre piece of any Triumph.
I'll be servicing, cleaning and reassembling the engine on my T140V and would like to dress it up.
I'd like to source:
Stainless Steel allen head screws & dome nuts for the Engine Cases, & tappet covers &
Stainless Steel or plated barrel to crank nuts.
Can anyone recommend any value for money kits?
Cheers,
Rock
I'd like to source:
Cheers,
Rock
