The 1927 H-D FHA racer, with its racing sidecar, little more than a padded platform. A remarkable original-condition racer from the end of the first Golden Age of American racing
The latest gem making the rounds of Instagram (and TheVintagent!) is this just unearthed, single-family for 50 years Harley-Davidson FHA 8-valve racer, which is documented and in as-last-raced condition. Huzzah; a no-bull 1920s Class A racer which doesn't appear to have been messed with or faked up, like nearly all the others of its ilk. Hilariously, some of the folks who've sold less than perfect American racers in the past few years have shown their hands with this machine, praising its originality and the importance thereof, while no such praise was possible for their own bikes! But that's the reality of most old racers - they're usually compromised in the very areas collectors prize most; matching #s, original sheet metal, clear provenance. When presented with a machine with all boxes ticked, the temperature rises.
The raised ring cast into the timing cover is the giveaway for a 4-cam timing chest. The oil pump is the horizontal cylinder behind that ring. Note the exhaust valve lifter emerging from the front of the case, operated by a small lever below the fuel tank. Although there are no bicycle cranks, a bicycle foot pedal is still used - a rider's affectation or original to the machine?
A nice engine shot showing the primary chain oiler, the ignition wires which thread between the barrels, and two further oil lines, one presumably to the rear of the front cylinder barrel, the other to the oil pump on the timing chest. Note also the small strap keeping the manual advance cable away from the exhaust. The carb is a racing Schebler - can one of my American racer experts fill in the type?
This machine is coming up for auction at Shannon's auction house on Sept. 21st, and I'll keep an eye on the sale.
A good shot of the struts attached to the early H-D forks, which help prevent flexing under the huge side loads from a sliding sidecar. Note also the small steering damper and slotted plate just below the top fork clamps. The handlebar bend is standar for board trackers.
Fantastic patina.
The FHA was delivered new to the Milledge Bros Harley-Davidson in Melbourne, Australia.
A period shot of the outfit, showing the braced forks, and the canted wheel angle for sliding on dirt tracks.
The simple direct-drive system is clear, with a countershaft running in a robust casting at the bottom of the frame, which holds the clutch and final drive sprocket. One speed!
For moto-geeks; note the attachment of the sidecar to a U shaped late and the reinforced engine plates up front. Plus the extensively ribbed drive-side crankcase. There's a direct oil line to the (missing) primary chain.
The oval port of the late 8-valve motor is clear, as is the single-rocker system used on a simple, pent-roof combustion chamer. All exposed, of course, to whatever dirt is thrown up by the track. Also clear is the camshaft layout, with side-by-side pushrods emerging from the timing chest - a cam for each cylinder, plus the crankshaft oiling line emerging from the front of the motor.
1927 FHA #81...not that they built so many!
Subscribe here to TheVintagent.com!
