is intergrated and can't find any instructions anywhere!
OK....I've removed both sides in the past (to change handlebars) and I remember that if you look at the FRONT of the Master Cylinder you will see screws to remove around the switch area...they go all the way through the master cylinder section and into the switch housing.
Here's a rather poor cellphone picture to help you find them (the one on the bottom left is obscured by the lever bolt):
