The cap is poorly designed. I am always finding it to be leaking or popped off. I am thinking a rubber cork that will fit under the cap will solo the problem? It should have been a threaded cap.
Any suggestions?
Any suggestions?
I will look for a blockage, did not think of that thank you.The expansion tank should be vented through the overflow pipe. If the cap pops off , is the expansion tank being pressurised by a blocked overflow pipe hose? The cap should not be threaded as this is ultimately a pressure relief mechanism
I wonder if it will take 9 months to get it from Triumph...LOLWorth trying a new cap? this has internal rib and external lip should fit snugly over expansion tank lip . My cap will not rotate on tank neck when fitted. part no. T210105 - about £2.50 GBP
Part # comes back as a chain. Can't find it anywhere.Worth trying a new cap? this has internal rib and external lip should fit snugly over expansion tank lip . My cap will not rotate on tank neck when fitted. part no. T210105 - about £2.50 GBP
Thank Elliot.oops part number is T2101015 try here for parts diagrams etc #Bikes
