Stephen55
Hi All, New to this group and rebuilding my 1975 T160 Trident. After a 60km test ride, there is a large oil seepage apparanly from the Rt hand exhaust port. ( also some weeping from the joint between exhust pips and silencer). I initial I suspected the either the upper rocker gaskets or head gasket. This does not appear the case and good compression has been tested in all three cylinders. I now suspect a worn valve guide although no signs were presented on rebuilding the head. Have any members experienced a similar upper cylinder leakages and/or diagnosed the problem
