2WheelersUnited
- Jul 10, 2022
- 8
- Age
- 31
- Location
- Tucson, AZ
- First Name
- John
- 2014 Triumph Thunderbird Commander
Hi all. I just acquired my first Triumph, a 2014 Thunderbird Commander that I got from my father in law after sitting in a shed for over a year (the bike, not my FIL). I'm having some (I think) unique ignition issues. I'll try to describe it here and go over my diagnostics thus far.
initially, the bike was missing a starter. Ordered the part, bench tested it -turned just fine. Installed it, hit the start button, and *CLUNK*. SH*T. Pulled it, cleaned brushes, reinstalled, and again, *CLUNK*.
New Battery, voltage is fine, doesn't drop below 12.5 volts. Pulled the handlebar controls and cleaned the contacts on the starter switch and the clutch switch. Tested voltage at the solenoid, and I get full battery voltage when I press the starter.
Next, I had the idea to jumper the starter motor solenoid directly from the battery, and it fired right up!
Back to the starter button, and still CLUNK CLUNK CLUNK.
I've done my best to trace wiring and check for shorts, but I think the manual posted here is slightly different than my bike. There is an "extra" relay that appears to be for the headlights, and the ecu Pinout is very different - 2 plugs, both black, with 3 rows of pins, not the black and grey connections like in the manual.
I did find a short in the position light circuit, but that's been repaired. I also did the pin point test for the ecm and starter relay - again, as best I could figure because the pin numbers are different than in the manual. The ONLY slight issue is a reading of .1 ohms on the ecm pin b15 to ground... Not even enough to "beep" my ddm, but it gets a reading other than "OL". But when I remove the relay, it goes away. I tried a new relay, and still there.
Is my ECU shot? Am I missing something obvious? I'm still thrown off since the starter runs and the bike will run when I jump the starter solenoid.
Any help would be greatly appreciated!
