Charp
I've been hearing a sort of dragging noise as I pull away from a stop. Other than the noise, the bike is running great. When I put the bike on a stand and spin the wheel, I can tell the chain is not spinning smoothly. I think this is the source of the noise. So, now I want to inspect and clean the front sprocket, which brings me to my questions.
I have 15K miles on this bike. Is that a reasonable life span if it turns out the chain is bad?
When changing a chain, should you always replace the front and rear sprockets?
How do I access the front sprocket? I removed the outer cover and the two screws for the inner cover, but the brake mechanism (pump?) is still in the way. In the image below it looks like I just need to remove the screw (1) and maybe unfasten the wire connector (2). Is there more to do? Any hints for making this job easier? And, is there a torque spec for that screw (1)?
Thanks in advance!
Thanks in advance!
