No worries Red, and I appreciate your being humble rather than defensive and angry. The last thing I want is to offend (unless we’re talking about the mother-in-law).
-Sparky
-Sparky
Thank you, Sparky and Red Dog. Valuable information!Thank you Sparky.
It's been I while since I tried to use gearing to explain an answer. I made mistakes along the way. Crunching numbers the way I was; it's easy to confuse yourself.
Changing the sprocket(s) will only affect the speedo if it runs off the engine or final drive. If the speedo is driven off a wheel, the wheel is still travelling across the road at the same speed, but the engine revs for that speed will be higher (smaller front sprocket) or lower (larger front sprocket). A larger front sprocket will also reduce the rate of acceleration.Did you correct the speedometer.
LoneRanger,Changing the sprocket(s) will only affect the speedo if it runs off the engine or final drive. If the speedo is driven off a wheel, the wheel is still travelling across the road at the same speed, but the engine revs for that speed will be higher (smaller front sprocket) or lower (larger front sprocket). A larger front sprocket will also reduce the rate of acceleration.
