I worked the local Gypsy rallye this weekend, so it's been a good break from the shop.
Slept in, had a leisurely morning and got out in the shop to start on the wiring harness. First thing was to install the rear fender while I could still easily reach in and around the front mounting tab area. Did a little bit of tweaking of the fender and grab bar to try to get all the bits to align nicely, but it seems the rear mounting tab on the grab bar is actually offset from the factory! that threw me for a 5-minute loop, then snugged everything down.
Next, a good wipe-down of the harness to get the dirt and grunge off it, then laid it in place across the frame and started snaking the front end through the headstock hole. What a chore! Even worse, had to dig up the disassembly photos and triple-check several pix to make sure I had the routing correct on the spaghetti bowl around the battery tray & coils, rectifier, etc. Then, verify wire colors to coils, observing the coil polarity, etc. Had to crimp in some bullet disconnects for the rectifier & alternator as the original bullets had been well and truly frozen in their multi-connector female lumps, so i had cut them off leaving enough length to work with. They'll be wrapped and "disappear" when it's all done.
After lunch, I installed the control quadrants & headlight shell, then connected all the dots. Wired in the keyswitch just to test; seems as though the headlight bulb might be fritzed, all it did was cast darkness in typical Lucas fashion. Ignition, battery, oil pressure sensor, starter relay, all wired in.
Took the rest of the afternoon to help a friend re-install the engine in his GoldWing, using my spare bike jack.
