Thank you I noted what lines were where on the pump. Hopefully will be okA very valid warningThis is easy to do and not realize it.
nJust need tires, front and rear master cylinders and do wiringThis thing is almost finished, great work! Looks like you will be on the road very soon!
But from where I started it's a piece of cake. Thanks to all at TrimuphTalkThat's a good days work yet to go!
Those "little" things can be so darn aggravating.
Amen
I had the exact same problem with my '78. turned out the brand/model of tire was JUST A BIT too wide. It would heat up and lock the rear brake.Moved to Norfolk Va last July only able to work on it since Covid will send new pictures. will have to revisit rear master cylinder it rubs on tire.
Are you sure you got the assembly order right on the wheel spacers? I'm trying to recall if the '78 had the speedo drive on thee caliper side, maybe not...The original master didn't rub though.
The width number moulded on a tyre wall is not the overall width.The original master didn't rub
