It's probably sacriledge to suggest a fly screen on the FL but I found on my Bobber that the flyscreen makes longer rides tolerable by taking about 85% of the wind pressure off my chest.
It may not be long before I’ll need to seek the Rocket and get something that weighs less. I’m having arm and hand issues. I’m thinking Bobber, T120 or 900 Scrambler.
I have a 2017 T120 that I enjoy riding, very much. Bought it as an in-town bike with my Rocket reserved for only touring and long haul duty. I upgraded the T120 suspension with some K-Techs in the back and progressive springs and pre-load caps in the front.It may not be long before I’ll need to seek the Rocket and get something that weighs less. I’m having arm and hand issues. I’m thinking Bobber, T120 or 900 Scrambler.
I’ve stayed away from tanks back because my fear is though scratch the tank
Magnetic base? If not, it will slide about, irrespective how good the straps appear to be (this from long distance touring since I bought my T160).tank bags
found this
can buy an inexpensive 1'x1' chunk of 1/4" thick neoprenestayed away from tanks back because my fear is though scratch the tank
One of the best "tank bags" I had was the first - a surplus nylon parachute bag, placed on a towel on the tank, secured by two bungees around the tank; black bin bag inside the parachute bag to keep the contents dry ...
Before, magnetic tank bags, I used to use a towel. Another thing I have done for many years is, when having a tank sprayed, I ask for additional clear lacquer coats, small scratches can then be polished out without affecting the paint; the theory was the lacquer can be be resprayed but, so far, that has not been needed.
On mine, the magnets are not only under the bag itself but also in two flaps that, when pulled apart from under the bag, each flap attaches to one side of the tank. Off the bike, the two flaps fold over the magnets under the bag itself, so the bag can be put down and the magnets will not pick up rubbish that could then scratch the tank.says magnetic but I can't detect any such thing.
Ah... I will have to take a look mañana. Maybe they're tucked up in there.On mine, the magnets are not only under the bag itself but also in two flaps that, when pulled apart from under the bag, each flap attaches to one side of the tank. Off the bike, the two flaps fold over the magnets under the bag itself, so the bag can be put down and the magnets will not pick up rubbish that could then scratch the tank.
Mine makes a quiet "clonk" as the magnets attach to the tank.
Had you thought of going tubeless? The work needed to seal the spoke nipples is not overly complicated. A puncture then becomes a task that can be tackled without even removing the wheel.Well, I could see breaking a bead and wiggling the tube out for repair. But actually R&Ring the tire with these shiny aluminum rims would be a task without gouging them up...
Regardless, yes to all items (thank you), though I may opt for a good bicycle pump rather than compressor, depending on how well the 3-phase alternator I've installed would handle the motor. I need to do some research and test its output. I'd hate to kill the battery fixing a tire.
Whilst on the subject of tyres you can get micro beads that are poured into the tyre through the valve stalk, obviously the valve needs removing first, that means no more stick on balancing weights.
Not had time to read this thread thoroughly to post any other suggestions but one wrench you might want to consider is Triumph 60-4531. Cannot post a photo,I'd appreciate additional suggestions for what is missing in a good over-the-road tool kit.
Not had time to read this thread thoroughly to post any other suggestions but one wrench you might want to consider is Triumph 60-4531. Cannot post a photo,it is a combination wrench but with a difference - the ring is 5/8" AF, fits the rear axle nut; the open end is 0.600" AF, fits the speedo cable nut at the rear wheel and the fuel tap nuts.
Originally only supplied in the T160 toolkit.
the ring is 5/8" AF
Tch, my bad;rear axle nut on my bike is around 15/16".
flat-slide or round-slide? either way, mikunis are an excellent choice for a 650 or 750 triumph. theyre easy to mount, easy to tune, and give excellent performance. but the VM version is a long carburetter compared to an amal concentric. if thats what youre fitting, you may end up having to modify your sidecovers again, although flat air filters will fit between the bellmouth and the old airbox brackets.I've ordered a pair of 30mm Mikunis, which should be here soon, I hope.
