I just got my 2009 triumph scrambler a couple of weeks ago. It has 17000 miles and it’s pretty great except a little quirk it has. The bike has a starting issue. I turn on the ignition switch, light turn on, switch on the run switch, Fuel pump engines,(at least that’s what I assume that noise is) then I go to it the start button and I get a click and then nothing. I then go to click it again and nothing. I could do this from anywhere from 1-20 times before my bike actually turns over and when it does it wakes up like nothing was wrong. So I check the battery and and it was 4 years old and it didn’t pass when I got it check so I replaced it. Hoping that would fix my problem I tried again and no change. Then I disassembled my starter switch and found a few webs. I cleaned this out put it back on and same issue. Anyone else run into this problem or know of what I should test next? I do have a multi meter.
