Sounds just like me![]()
Careful, I might adjust my first over-the-road trip to show up and mooch a glass...
That looks amazing, great job. I bought a bench mounted buffer to do those kind of jobs. Easier on the hands.
About 38 degrees BTDC. If you want absolute accuracy, it is as well to verify with the factory tool that picks up on divots in the flywheel.is the rotor mark TDC or 38 BTDC
Lucas alternator rotors with two marks 180 degrees apart were first made for the 71 model year; Triumph and BSA had intended to introduce a new range of 350 cc parallel twins (Triumph Bandit, BSA Fury) with 180 degree cranks. The entire project was subsequently abandoned during 1971 due to the BSA Group's worsening financial situation and development difficulties with the completely new engine.what's the deal with two marks?
Afaict the rotor in the video is not standard for a twin: its part number has only seven figures and begins with a "4"(?); 71 650 parts book lists 54213901, that Lucas part number is listed in all 62 on singles and twins parts books, when Lucas first supplied 74 mm o.d. rotors and matching stators.here is Lunmad's video (rest his soul) on timing marks. At 4:32 into the video, he mentions alternator rotors like mine, and indicates that in his experience, the rotors with two little rectangles each containing a hash mark, one of them is TDC and not 38 BTDC.
Then, for 76, Triumph fitted the 750 twins with a new primary chaincase, that replaced the separate cover over the alternator rotor and the fixed timing pointer in about the five o'clock position, with a smaller plug in the chaincase 180 degrees from the previous timing pointer position. However, obviously there was/is no control over whether a new rotor was/is fitted to a 76 on or pre-76 bike, so rotors had/have two marks 180 degrees apart.
You are amazing!Yup, going by the divots in the crank, looks like the rotor mark is right on 38 BTDC, per first photo (I made a 'T' for TDC to facilitate valve accurate adjustments). I set the BB ignition per its instructions, which use the 38 BTDC 'full advance' mark for initial timing.
As for initial oil level, I added proportionately the same amount above the primary chain case 'prime' amount called for in the '71 T120R manual, as the author of 'Waking the Sleeping Beast' suggests exceeding the corresponding prime amount for triples.
I did this slowly, and each time I poured--for a little while, anyway--the level eased down as the oil seeped back into the crankcase through the three teensy holes. I stopped when this equalization process stopped (I think this was on the side stand). You can't see it in the timing marks photo, but I ended up with oil immersing the bottom of the stator with the bike on its side stand.
Question: should I add a touch into the crankcase via the timing plug, even though the author of "Sleeping Beast" doesn't do that?
As the next two photos show, here is the oil level with 1-1/2 qts poured into the integral oil tank (dipstick is roughly where it would sit inside the tube: the bottom tab has the 'add' mark). Frankly, I'm a little uneasy with having it that low for startup, but this seems to be the usual practice to avoid the tank overflowing...?
Anyway, everything else is ready to go: valves adjusted, petcocks sealed up to the tank, fuel lines attached, intake and exhaust fasteners tightened... I hope to have time tomorrow or over the weekend to go grab some gas, oil the valve train per 'Waking the Sleeping Beast,' and give her a go!
I think there may be suggested initial settings in the Amal literature The tuning guide merely discusses what role the low-speed/idle mixture screws play--but not where to start out, re: [x] turns from seated.
We'll see what happens...
You are amazing!
I would be surprised if they are not the same part, Emgo and Wassell ("Lucas") co-operate on parts sourced in the Far East.I noticed the differing part numbers when ordering but both TBS and KM Jones (the OIF parts house) offer just one Lucas rotor--with the twin marks 180 degrees apart (KM Jones is far cheaper for the same part). KM Jones also offers an Emgo part for $120, but I went with a Lucas rotor, perhaps stupidly...
"Waking The Sleeping Beast" was written for triple owners, triple timing plug is in a completely different place from a twin's (about half way down the front of the timing side crankcase).should I add a touch into the crankcase via the timing plug, even though the author of "Sleeping Beast" doesn't do that?
As I fall asleep tonight instead of sheep it'll be a final to-do list spooling before my mind's eye
Also certainly Wassell calls it the "RM20" rotor. RM20 was another 3-wire single-phase stator, more powerful than the RM19 standard between 62 and 68; I believe the RM20 was supplied on bikes for the police? RM20 produced about the same Amps as the RM21, RM20 were fitted to 69 triples when the RM21 was fitted to twins (possibly BSA did a deal with contemporary Lucas to use up the last RM20 as BSA planned to build only a few thousand 69 triples?).
My understanding has always been the RM20 rotor was wider than the RM21; however, I have not had two originals side by side. No difficulties fitting a Wassell "RM20" rotor in a twin posted in any of the forums.
Fwiw, agree with your "initial oil level, I added proportionately the same amount above the primary chain case 'prime' amount called for in the '71 T120R manual ... I stopped when this equalization process stopped ... ended up with oil immersing the bottom of the stator with the bike on its side stand", except I would do it with bike on the centrestand, or at least propped vertical.
Most of it should be gone once the engine's been run, the extra oil in the crankcase and chaincase has been scavenged into the frame. Although, as you have noticed, excess in the chaincase does not drain very quickly into the crankcase.may experiment with dribbling a little oil into the crankcase via the timing plug hole, watching the level in the primary chain case to avoid it overflowing during dynamic timing.
Even when the primary oil is down to a 'normal' level, as the bottom run of the chain drags in it, expect a fine spray out of the chaincase when it is open for timing ...Round bit of perspex or similar to fill the hole in the primary during timing?
