Enjoy reading your journey of rehabing an old scoot. Am interested in how it performs once completed.
Me too. Great to follow this and looking forward to the finished productEnjoy reading your journey of rehabing an old scoot. Am interested in how it performs once completed.
This has become THE most popular thread on this forum!Here's where I am thus far:
... And away we go...
Oh yeah, we're loving itWell, now I'm going to have to shave and shower every morning...
Seriously, though, I'm glad it's useful or entertaining or both.
No! Never.the 'general data' says 25 ft. lbs. for the front spindle (axle) cap retaining nuts. Really?
No! Never.
It's a misprint, hangover from the pre 71 steel sliders and axle caps.
In something like 79, Meriden finally changed the torque figure to 15 ft lbs on the similar disc brake alloy sliders and axle caps but imho that is still much too high.
Because of the failure of NVT within a year of launching the T160, the official workshop manual (still with the misprint) did not appear until the early 1980's. By then, I had had my T160 for several years; first time I had to tighten the axle cap nuts, I looked at the enormous gap between slider and cap, did the nuts up equally either side of the axle with an ordinary wrench 'til they were "tight". Always done all those cap nuts that way ever since, never cracked a single cap (my T160 still has its now 49 year old originals ...
Fwiw, I have never had an axle cap nut come loose; my T160 has both plain washers and oblong section spring washers between each axle cap and its nuts; alternatively, I fit all metal Staytite self locking nuts with just plain washers.intend to include a 7/16" wrench in the under-seat tool kit I'm assembling. I'll likely make it a habit to give them a nip whenever I fill the tank. Only takes 30 seconds, and it'll give me peace of mind
Friend of mine, also a long-time T160 owner but a proper mechanical engineerexplained I was likely bending the cap elastically; so bent imparts considerable additional friction between nut and stud threads but a cap returns to its original shape when the nuts are loosened. He surmised particularly original cast caps probably transition quickly from elastic to plastic bending when they crack.
"It's been a long time since I rode the presumably analogous '71 Yamaha XS1B 650 that I owned in the early '80s."
I've owned a number of the old XS 650's, the last two I owned I shipped to Australia to a collector. Here's a pic I took of one of those bikes after getting it cheap as a non runner from a friend. That's a stroll down memory lane........(thank God for Mike's XS.com for parts)
Not only do all the different OEM Triumph front axles have the "collar" (that primarily locates the axle relative to the hub through the fixed bearing), almost all also have a semi-circular cutaway around the axle close to each end, the cutaway locates between the bolts or studs (outer studs on your bike's forks) into each slider, these bolts or studs are closer together than the diameter of most of the axle.The OEM setup has an axle (if I'm reading the diagram in the manual correctly) that has a collar machined into it near the center...? So, no way the axle could slip sideways out of the caps. However, I am using a simple piece of (very hard) steel as an axle: the only thing preventing its lateral movement is the clamping force from the caps, and of course the weight of the bike.
Therefore, I had mused about having my neighbor/machinist turn grooves for circlips into the ends (there's ample length to do that).
When the Co-op changed to 3-phase alternator stators, they had to change the mounting nuts and washers - to small hex and small o.d. respectively - because Lucas crammed in nine stator coils in the same space as six in single-phase stators. However, what the Co-op never did was change the nuts and washers part numbers in the parts books ...had to gently carve out some of the molded plastic around the alternator stator's nuts to get a socket on them.
What the manual does not show or mention is the child labourer pressing down on the kickstart against compression to get all the chain slack in the top run ...Question:
When the Co-op changed to 3-phase alternator stators, they had to change the mounting nuts and washers - to small hex and small o.d. respectively - because Lucas crammed in nine stator coils in the same space as six in single-phase stators. However, what the Co-op never did was change the nuts and washers part numbers in the parts books ...fwiw, I use 21-2177 nuts and 70-3446 washers.
What the manual does not show or mention is the child labourer pressing down on the kickstart against compression to get all the chain slack in the top run ...Then I both push the chain down and pull it up to measure the total slack.
