billerbeck
I have a 1977 TR7RV that I am freshening up. It's actually in quite good condition for its age. Looking at the major bolts and nuts on the machine, it doesn't appear to have ever been apart. But there is missing and worn paint in some spots that I would like to freshen up. I'm working on the rear of the bike right now and the swingarm and muffler hangers could really stand to be resprayed. Do you recommend powder coating or rattle can for this job? If rattle can, what brand of paint have you found to be good (durability, color match, etc.)?
I'm also replacing the rear tire/tube/rim tape and noticed that the wheel bearings are of the non-sealed type (with some pretty old, grungy looking grease in there). I see that sealed bearings are available and thought that might be a good upgrade at this point. Any experience with using sealed bearings on these bikes? It looks like bearing part number 6205 is the correct one. Any brand or supplier in particular that you like? Would any locally sourced 6205 bearing work?
The rear wheel is in very good condition . . . no missing paint on the hub, good chrome on the rim, not bent or dinged, spokes are tight, wheel is true. But the spokes have taken on a dull, gray look. They are not rusted, just kind of dull looking. Any suggestions on improving the looks of the spokes? Are the original spokes plain steel? If I were to have the wheel re-laced with new spokes, do you have any recommendations re/ which shop to use and type of spokes to use?
A lot of questions, I know. More to follow, I'm sure. I'm just getting started. Thanks in advance.
