made the changes one by one.
I did pull one spark plug at a time, grounded to the engine head, and turned the key on and off, had a spark on each one.
Not able to start. No pop at all...
Boyer Transistor Box connected as above, unscrew at least one of the spark plugs from the head, reconnect the plug to its cap, lay the plug on the head ensuring the plug has a good 'ground' to the head, turn the ignition switch on and off; each time you turn the switch off, the plug should spark
Next test was/is to check the plug sparks when the engine is turned over.
If you do not see the plug spark when you kick the engine over, the Transistor Box is not receiving trigger signals from the Boyer "Stator" (where the points and auto advance unit used to be in the engine timing cover). The fault/s could be one or more of the following:-
. the Boyer "Rotor" is not turning with the camshaft;
. the Boyer Rotor has slipped out of position (note the warning in the Boyer fitting instructions that the supplied rotor securing bolt might be too long).
. If the Rotor is in the correct position, measure the resistance across the Boyer Stator and the resistance of the wires connecting the Stator to the Transistor Box. Your meter:-
.. Is it fitted with a known good battery?
.. When you use it to measure Ohms, does it: zero automatically when you hold the lead ends together; or does it have a thumbwheel to zero it when you hold the lead ends together; or do you have to hold the lead ends together, note the meter reading, subtract it from subsequent readings?
. Once your meter is either zeroed or you know the figure to subtract:-
.. unplug the two Boyer Stator wires, insert one meter lead end in each Stator wire socket, your meter should display 137 Ohms (corrected if necessary) or very close to it; wiggle the Stator wires around while ensuring the meter display does not change (change would indicate a partially broken wire or other contact fault);
.. if the meter does display 137 Ohms or very close to it without any changes, reconnect the wires from the Transistor Box to the corresponding Stator wires, unplug the same wires from the Transistor Box, repeat the same test above, one meter lead end in/on each wire from the Stator; the reading should be the same 137 Ohms or very close to it to indicate the wires between Stator and Transistor Box do not have any measurable resistance.
going to flush out the tank again, and drop the bowls on each carburetor and clean them completely
More simply, unscrew each float bowl drain in turn, hold something underneath the bowl to catch liquid, open each fuel tap in turn, allow fuel to run out of the bowl for one minute, thirty, twenty, fifteen or ten seconds (the longer the better), turn off the tap, measure the fuel that has run out and equate it to 300 millilitres/10 US fluid ounces per minute.
Unless fuel is flowing at significantly less than 300 ml/10 oz per minute, you know there is no need to flush out the tank, unlikely to be any need to dismantle the carbs unless to check the pilot jets are not blocked (it would be surprising if both had blocked up overnight).
