Doc Triumph
Just changed oil in my 2018 Speedmaster. Topped off went for a ride and now oil warning light is on. Wonder if too much oil pressure will cause this.
I've had two Americas with the oil light coming on, on a cold morning. In both issues it was humidity on the oil electrical sensor device behind the heads. Remove the rubber cover from the oil sensor and apply a squirt of WD40 to chase away the moisture.......sorted!Just changed oil in my 2018 Speedmaster. Topped off went for a ride and now oil warning light is on. Wonder if too much oil pressure will cause this.
