The built in error does NOT affect the odometer - unless you change the gearing. In other words, the bike knows the actual speed.
I don't ride on the interstates; I'm running around on Farm to Market and dirt roads in the country.
It is generally advantageous to have the latest factory tune loaded. Triumph releases tunes to fix problems that have been found and to improve the overall performance. Usually, but not always, Triumph releases two tunes simultaneously; one for non-ABS bikes and one for ABS bikes. I have not messed with the throttle body balance; so I can't help you there.
You are very welcome. Sounds like a plan. Let us know how it goes.
Very good.I loaded the newer map on the bike this weekend. It had map #20630 and I updated to #20770 (800XC, non-abs, standard exhaust). Did not make any changes to the tune; loaded as is.
The only part of the procedure that did not go as planned was the TPS reset. Could not find the command on the Tune ECU program. After loading the tune I reset the Adaptive, ignition off, ignition on for 10 seconds and ignition off, reset Adaptive again just to be sure. Started the bike, without touching the throttle, and after 15 minutes the TPS light went to green.
I noticed smoother throttle response right away. I don't have the latest ABS tune (20771). I will get that in about week. I have to take the bike to the dealer for the 12,000 miles; I cannot do the valve check myself. Most of the other stuff, I have already done myself pertaining to the 12, 000 mile service. The dealer does not charge me to load the the latest maps.Took it out for a quick run. First thing I notice is the fuel gauge is responding quicker; reading accurately by the time I reached the end of my block. Normally takes 3-4 minutes before it reads correctly. The throttle response seems smoother, especially on take off. Probably cured some other issues that I am not aware of yet.
This is strictly my opinion based on experience and with talking with knowledgeable folks. An engine with a more free flowing exhaust needs more air flow at the intake. Without that, the engine will run on the lean side which means it will run hotter.There is a tune for the Arrow exhaust (20771) that I might try next. Don't have the Arrow, but have the Vince L exhaust.
I went ahead and ordered the Dealertool software and cable to further analyze the balance of the throttle bodies and also to be able to control the service "wrench" icon.
I have chosen to run non-ethanol fuel in all of my bikes. In my 800XC, I run marine gasoline which is 92 or 93 octane.It is like mid grade automotive gasoline - except no ethanol. I also use these in all of my small engines - lawnmowers, weed whackers, chain saws, etc. When I am on the road and cannot find marine gas, I run 87 octane automotive gasoline. In my TR6R, I run racing fuel or marine gas. Before I started using marine gas, I did run mid grade (93 octane) in my 800XC in the summer when riding two up.Question to the group, what octane fuel do you run? I am running 87 octane.
Carl, has there been a Poll run on this question? If not, might be a good one. Thanks, John
Hey John,
I'm with Carl and let the adaptive tune do its thing. Never had to touch mine, however I still run the standard muffler.
On your inspiration, I fitted a 15 tooth front sprocket. Took it out into the hills both tarmac and dirt roads. It has sharpened the performance appreciably and the connection between the throttle and rear wheel feels more direct. No change in fuel consumption for spirited riding.
I use non ethanol 91 octane.
You are very welcome. Let us know how it does the the Arrow tune.
