You plan on doing a lot of breaking down then Carl ?
Here’s something I consider a big improvement for the 850 S . It’s just a piece of 1/2 inch plastic packaging foam cut to fit , keeps the intake noise way down for cruising but allows plenty under acceleration to remind you it’s got pistons . Acts as a roof for the battery and some wires under there . The 900 models don’t need it , they have their toolkit tray in the same position.I hard wired my TomTom to the same connector so it is switched with the ignition switch. I've not had any issues since doing this about 6 months ago
RAC being the Royal Auto Club I assume . We have CAA here in the Big ColonyYes, as part of the bike purchase package we get two years membership of the RAC which covers us for breakdowns with attendance roadside and transport to a local garage or back home. I think it covers us for Eastern Europe as well.
Sounds very much like the stepper motor issue which the 2011tigers experiencedThis is a very interesting thread. My 2023 900 GTPro did something similar to me a couple weeks ago with only 85 miles on it but I was away from home. When I turned the key on the dash lit up but the fuel pump would not cycle. Sat there for about 15 minutes turning it on and off then it finally cycled and started but once started it had a check engine light. Took to the nearest dealer which was 1.5 hr away and they did some tests and said that the dealer i purchased it from did not complete the setup after assembly correctly. They finished the process and said it was good. Drove back out and picked the bike up, went to take it for a ride last Friday and the same exact issue. After 3 tries with the key it fired but again, check engine light. It is back at the dealer now and they are trying to determine what is going on. It would be good if it is just the key, I will mention it to them and see if that could be it.
AAA in the States will cover motorcycles at an additional charge.RAC being the Royal Auto Club I assume . We have CAA here in the Big Colony
, for our Cars of course but they did cover the tow bill for the flat on the Thruxton a couple of years ago . AAA probably does the same in the Rebel States .
Yup same here. Used my CAA when had a front flat on the T'bird years ago. I have the RV plus package as if my truck quits, need something to tow the trailer as well. Includes the bike.AAA in the States will cover motorcycles at an additional charge.
I don't use AAA. My motorcycle insurance has a recovery and towing provision to it and if I have to use a motorcycle tow; that's what I use.Yes, Royal Automobile Club. One of their membership options is not to cover the vehicle but to cover the person. Insofar, irrespective of what vehicle you ar travelling in, or who owns it and whether you are the driver or not if that vehicle breaks down you are covered for onward transport to your destination or recovery back home.
We also have the Automobile Association in the UK plus a whole host of lesser organisations providing breakdown and/or recovery services.
I just bought a new 2023 Triumph 900GT Pro and have only about 60 miles on it. I added a usb plug to the front power socket and have the Quad Lock wireless charger plugged into it. The bike hasn’t been started in about a week and when I went out today the battery was dead. I didn’t think the LED light for the sub plug would draw enough power to kill the battery in a week. I figured since I have to access the battery I’ll add the accessory cable so I can easily hookup a battery tender during the winter months. I added the cable and I let it charge for awhile. When I went to try it the bike would not turn over and the TFT screen says it’s out of fuel and also shows the shock icon. I know it’s not out if fuel since I topped it off about 10 miles ago. I’m going to let it charge overnight, but if nothing changes any ideas what the issue could be? The dealer is about 30 miles away and I’d rather not bring it there if I don’t have to.
Was the aftermarket USB port unplugged from the charger? I’d try unplugging it and disconnecting the battery, wait a bit and then re-hook up the battery and see what the system does. If it starts up then reattach the USB. Just a tought if you haven’t tried it.Hi DJ
I too have a 23 GTPRO and after the battery going flat I charged it up - got all the dash lights and I can hear the fuel pump engaged but the starter will not engage. My bike has less than 400 miles on it. I noticed that several people have reported 'reprogramming' a key but my key is (I am pretty sure) not a smart key. The only thing that I have in common with some others that have reported similar issues is that I have an aftermarket plug-in USB port in the front charger but that hadnt previously been a problem.
I am interested to see how well my dealer supports this problem.
So, back on my super reliable Royal Enfield this morning to commute to work on a rare nice day in Nottinghamshire ... all the best
Hi SikatriWas the aftermarket USB port unplugged from the charger? I’d try unplugging it and disconnecting the battery, wait a bit and then re-hook up the battery and see what the system does. If it starts up then reattach the USB. Just a tought if you haven’t tried it.
So it turned out the fix wasn't as simple as I had hoped. After getting bike back, took for a ride from Upstate NY to RI and about an hour out, stopped for gas, went to start back up with same issue. This time it finally started but the screen was all jacked up. Colors were mixed but I could still see speed and other data so completed ride to RI. Turned bike off, removed key and dash was still lit up. Went to dinner leaving bike at house and hot back, still glowing in the night. Disconnect battery to shut off screen. Reconnect and all good. Took to dealer in CT since none in RI. Triumph USA had to get involved to figure out issue. Had to replace computer screen. At same time I decided to not use front USB port unless bike is running. No longer have that issue but now it has been back in CT shop 2 weeks ago for TES error light. Called dealer yesterday and Triumph USA is sending new rear shock but no idea what eta is so needless to say, my faith in the new Triumph electronics is nill. I have always heard about the poor electronics way back in the day when they used Lucas but I think they have gone back to another crap supplier. Have always been a huge fan of all my triumphs but this will more than likely be the last one I own.This is a very interesting thread. My 2023 900 GTPro did something similar to me a couple weeks ago with only 85 miles on it but I was away from home. When I turned the key on the dash lit up but the fuel pump would not cycle. Sat there for about 15 minutes turning it on and off then it finally cycled and started but once started it had a check engine light. Took to the nearest dealer which was 1.5 hr away and they did some tests and said that the dealer i purchased it from did not complete the setup after assembly correctly. They finished the process and said it was good. Drove back out and picked the bike up, went to take it for a ride last Friday and the same exact issue. After 3 tries with the key it fired but again, check engine light. It is back at the dealer now and they are trying to determine what is going on. It would be good if it is just the key, I will mention it to them and see if that could be it.
