A few items sorted out today:
Separated all the hardware for OEM head steady and installed it (will have Taylor for the final build, it's already on the way), and mounted the rev-tech dual-lead coil and wired it in. (no pix)
Installed all of the OEM electric start primary system after fiddling with the back spacing on the chaincase standoff lug for way too long (they sent me the wrong part and I had to space it with bits I had on hand). Installed the Spax 3-phase alternator and wasted another 20 minutes reworking the outer diameter of the rotor nut to better fit the new rotor (it was just a bit to snug to catch the threads properly). I also plugged up the shifter cross shaft opening with the stub end of a shifter rubber RTV'ed in place.
I need to pop the clutch cover back off and add a stuffer plate, the lever pull is too stiff for my taste, but the clutch is working.
I cut a relatively thin section of sheet metal to mock up the electrical panel, and mounted all the components (except horn relay, it'll go on the lower left side)-
Final version will be sturdier material, I didn't have anything heavier to work with right on hand at the moment.
Last item was the rearset pegs; it turns out I was able to use the Kawasaki rear brake pedal mounting base, cut, shaved and re-drilled to accommodate the orientation for Left-foot disc brake master cylinder-
Just need to chop off the excess bit of bracket after I bolt up some sort of triangulating stiffener, then overhaul & connec the rear caliper (the Nissin won't work).
