Some of the ones I have seen seen have a small tank for each "station". You mentioned 20L which would be a little over 5 US gallons. I have not done thorough research on these systems; but I understand that the small thank tanks get you started with hot water. Then water is heated as it comes through when you are using it - washing dishes, showering, etc. They save on water because you don't have to let the water run for several minutes before you get hot water at the tap.
I will be researching this thoroughly as I prepare to buy the farmhouse in North Carolina. I am going to remodel the bathroom and kitchen anyway and add central heat and air conditioning. I am looking for the most energy efficient and cost effective way of doing this.
Thanks, Kevin. I was not aware that you did not have mix with the cold.
Hi Dave, have you looked at solar heating?
You certainly can mix hot and cold if you like to but it's unnecessary to heat water and then cool it down with cold. We have a touch-pad in the kitchen and bathroom, if say you were using 55c at the kitchen sink and want a shower we just push the down arrow in the bathroom a few times to the desired temp for a shower. We use 55c in the kitchen and depending on the season vary between 37c and 41c in the bathroom. This system of not storing hot water works best for up to 3 or 4 people at about 4 or more family users stored hot water can be cheaper.
I recalled a similar conversation some time back and went back and found this. Look at post #22 in this thread, I posted a photo of the set up.
https://www.triumphtalk.com/showthread.php/16972-Electrical-Appliances/page3?highlight=water
I didn't spend a lot of time reading on the system you linked to but I may be able to answer some questions on how they work here. Generally you have two different systems here, one is a tankless water system either gas or electric. This system replaces the the most common system used here today, the 30 to 60 gallon water heater. The tankless system is rated by GPM (gallons per minute) flow capabilities so the larger the house or the more folks using the system you would probably want to run with a larger GPM much like you would want to have a tank sized for your house and/or family size. The second system is a local tankless water heater, it only provides hot water to one location such as the bathroom and it too comes with a rating here in the States as per it's GPM. The difference in this system is it is smaller, is sized for just one room and in theory can be more economical. I say in theory because I haven't seen the savings numbers on this system versus the larger tankless system, I've only seen the savings in it versus the 30-60 gallon tank systems.
